SST Trans Temp Gauge w/OEM Pan - Page 5 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 06-03-2014, 06:38 AM   #41
Evodon84
Evodon84's Avatar
Originally Posted by yz450f View Post
The torque app shows a tranny temp. This temp is identical to coolant temp at all times. Torque app supports custom PID's. Does anyone know the correct PID for tranny temp?????? Or do I have to run Evoscan or hardwire a gauge for accurate tranny temp?
Is this true that the tranny temp is always the same as the coolant temp? I wouldn't mind just using torque. I've got an extra android phone I could use in the car.
Beeble Tewnd!
CNT RS Exhaust
Evodon84 is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:39 AM   #42
Burke
Member
Is there is a link with the updated pictures from the first post? They appear to be broken or removed.
Burke is offline   Reply With Quote Quick reply to this message
Old 05-26-2017, 11:23 AM   #43
landis
Member
I have a temperature sender plumbed into drain plug in the SST. The temperature of the transmission isn't identical to the water temperature.
landis is offline   Reply With Quote Quick reply to this message
Old 06-07-2017, 03:07 AM   #44
Burke
Member
Does this hang low?
Old 06-15-2017, 05:36 PM   #45
Burke
Member
I'm curious if this will crash into my skid plate
Old 06-15-2017, 10:30 PM   #46
c08
Member
I also think you can monitor TC-SST temp via OBD2 with the torque app, but you need to install the MUT plugin and may also have to patch your ECU (I know you do for Mode 23 PIDs but not sure about Mode 21). That plugin also gives you things like clutch pressures/speeds and temps. I haven't tried it yet but I plan to at some point.
If you try to use the transmission temp out of the box with torque I think it just gives you the coolant temp (which is what some others in this thread were seeing).
c08 is offline   Reply With Quote Quick reply to this message
Old 06-17-2017, 08:18 PM   #47
Burke
Member
Mut plugin? I'll look into it
Old 06-18-2017, 01:02 AM   #48
c08
Member
Here is the plugin: https://play.google.com/store/apps/d...in_TQPro&hl=en
Here are instructions I found to install it: https://www.evoxforums.com/forums/sho...3&postcount=69
Like I said you might have to enable Mode 23 too for the plugin to work, but I'm not sure.
Old 09-07-2017, 01:13 AM   #49
forcefedjunkie
Member
You can read same trans/clutch parameters with the Aeroforce gauge.
2010 MR
forcefedjunkie is offline   Reply With Quote Quick reply to this message
Old 01-14-2019, 03:52 AM   #50
Strider327
Member
Bringing a thread back from the dead in 2019. So I'm planning to pick up a Tanabe Oil Temp Gauge kit. Part Number: 1TRAA003.
A 1/8 NPT Female to M16X1.5 Male Pressure Gauge Adapter is also needed. Part Number (AM2268)
This should complete the kit of having a SST Temp Gauge to know when you can rip on your EVO X MR or Ralliart. The Normal Operating Temp should be at 190F.
Strider327 is offline   Reply With Quote Quick reply to this message
AEM Transmission Temp Gauge 4832 SST 13 07-15-2010 03:38 PM
DIY SST Trans Temp Gauge Martin Donnon SST 44 01-25-2010 02:18 AM
engine temp question! sbkim Evo X General 3 01-17-2010 05:25 AM
User Remark on SSP clutch pad, trans-cooler,AMS trans-cooler & Willall oil superlemonevo SST 21 09-21-2009 03:59 AM
SST Trans Temp Gauge TheSin SST 10 03-14-2009 01:45 AM
