Climate control color changes - Page 21 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Vanity
Evo X Vanity Discuss body kits, wings, interior mods, etc having to do with the appearance of the Evo X. Do NOT post detailing threads here.
Old 05-01-2015, 04:45 PM   #201
AdhesiveTeflon
AdhesiveTeflon's Avatar
I'm going to try it while my car is down. The only problem is that any other color other than red/orange kills our night vision so I'm hoping it isn't super bright in my eyes.
I've yet to lay my ears upon a Tomei but for anyone that has heard a ETS quiet which is what I came from, its about the same loudness until you go WOT, then the ETS screams like a bitch gettin in the ass for the first time whilst the akra is more akin to a 20 year old girl moaning and groaning loudly in your ear but in a sexy way. It's loud but you're loving every second of it.
AdhesiveTeflon is offline   Reply With Quote Quick reply to this message
Old 05-04-2015, 02:30 PM   #202
cheezeboy
cheezeboy's Avatar
I didn't think about night vision colors. I've had no issues with white, nor is it distracting. As long as you stay below the rating I suggested below, it should be fine.
Originally Posted by cheezeboy View Post
My suggestion is not to use anything over 400mcd. I think anything higher than that would be too bright.
...this individual is indeed engaged in the occupation of selling their dumper to other dudes.
cheezeboy is offline   Reply With Quote Quick reply to this message
Old 05-14-2015, 04:23 PM   #203
MA70Snowman
Member
I've been rocking my conversion since early 2011, all LED's are still going strong. I love the look, and mixed in white with the blue to make it really pop. It's great seeing other evos and then looking in their interior and I always forget mine is not stock, I see the orange/amber and I just can't imagine driving in that.
I've done a number of conversions across CA for fellow evo owners, and have done cross country work so do a google for my name and you might find some things, but here's one of my threads I posted here on EvoXforums and you can check it out. Since then I've done 8s,9s,10s to include stock radio and nav units.
https://www.evoxforums.com/forums/showthread.php?t=44865
MA70Snowman is offline   Reply With Quote Quick reply to this message
Old 05-14-2015, 04:25 PM   #204
AdhesiveTeflon
Yea I ordered the LEDs...I don't even know how I'll be able to work with something that small.
Giggity.
Old 05-25-2015, 03:53 AM   #205
elocinx671
Mine are still going strong!
elocinx671 is offline   Reply With Quote Quick reply to this message
Old 12-06-2015, 09:42 PM   #206
meeklo062704
Sorry for resurrecting and old thread, but whats the best way to power the pcb when it is out of the car? I just want to be able to give it some power to check all of the leds before reinstalling and finding out i goofed on one. I tested my boost gauge when I first got it by hooking it up to an old computer power supply. Would the same work for the hvac pcb?
meeklo062704 is offline   Reply With Quote Quick reply to this message
Old 12-07-2015, 07:06 PM   #207
cheezeboy
cheezeboy's Avatar
I suppose an external power supply could be an option if you found the correct inputs on the board. However, it might just be easier to just reconnect it in the car without remounting it, and turn the headlights on.
I just used the diode setting of my multimeter to check for proper polarity and solder joints. When correct, it made the LEDs light up ever so slightly.
Old 12-10-2015, 10:13 AM   #208
meeklo062704
So I finally got the hvac controls done. Had a little setback when I didn't check the cathode/anode markings were correct... They were backwards, so I had to do it twice. That's what I get for going cheap and ordering bulk from Amazon.
The only instructions I've found online for accessing the steering wheel controls requires taking the steering wheel off. Is this the only way, or did I miss another write-up somewhere? Also, is there a part number for the little bulbs inside the buttons? ASC, AWC, headlight leveler.... I had a tough time finding replacements, and am about to just take off the orange cover and color the bulbs blue.
Old 12-11-2015, 01:50 PM   #209
cheezeboy
cheezeboy's Avatar
It's been awhile, but I'm pretty positive the steering wheel has to come off. There's not really anyway around it. This was the part that scared me the most, but it ended up being fine. Just mark the position it's at before removing it. I used the dust on top.
Also, it may go without saying, but disconnect the battery before removing the airbag. Better safe than boom.
I'm not sure on a part number. I just hacked up a resistor with an LED and reused the bulb holder. I wanted the colors to match exactly.
Old 12-11-2015, 04:37 PM   #210
meeklo062704
I knew something would go wrong eventually. AWD, ASC, and headlight leveling switch are giving problems now. The AWD button works, but wont light up. The ASC button doesn't light up or work, ASC is automatically turned off when I start up. The headlight leveler doesn't light up, but i got the leveling working again. Doesnt surprise me at all that its having issues. I would think there would be a slightly more elegant solution than a cheap metallic claw stuck to a pcb with grease.
I tried searching for some troubleshooting, but the results are always for the function of the switch instead of the switch itself.
Any ideas what would cause a switch to not function when it seems it should be? It isnt dependent on the bulb completing a circuit is it?
Edit: I found it in the service manual. The bulbs complete the circuit between terminals 1 and 2, and they have to be in just right. Just out of curiousity, what size leds and which resistors should i use if i want to swap them out?
4/Sale: *NEW* AP Carbon Fibre Gauge Pod (Triple 52mm, mounts below climate controls) PROJEKX Completed Transactions 2 12-31-2009 04:50 PM
Wondering about driveabiliy in hot climate vs cold climate irmerm Evo X General 17 08-28-2009 11:03 PM
Moving to HOT climate! Which air induction? Olaboy808 Evo X Performance 19 05-14-2009 06:47 PM
Canadian (Cold climate) Evo X Owners TheSin Evo X General 19 12-21-2008 04:57 AM
what color ak47m203 Evo X General 86 10-11-2007 09:55 PM
