New 3" Intake Option from MAPerformance! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > MAPerformance
MAPerformance MAPerformance
Old 10-28-2015, 09:46 PM   #1
Maperformance
[Elite Merchant]
Maperformance's Avatar
The Quality You Expect at the Price You Want!
Our 3" short ram intake was designed for use with aftermarket lower intercooler pipes such as the AMS and ETS kits. Also works with the stock lower intercooler pipe. These lower FMIC pipes relocate the BOV return closer to the front of the vehicle, making your factory BOV system useless. Furthermore, removal of the recirculated BOV setup requires additional work, such as a tune. This is not always an option for those budget minded individuals. So a convenient aftermarket option was needed.
The MAPerformance Evo X Intake Kit features a 3" 304 stainless steel tube. Why stainless you ask? It's a well known fact that steel reduces heat absorption compared to aluminum tubing. Lower heat improves power capacity with the stock mass airflow sensor, so our kit will not require tuning or scaling. Capped off with a massive 6" velocity stack, coupled with a high-flow Green Filter air filter, you'll get maximum induction performance.
Included Components
  • Intake Pipe with CNC machined MAF sensor housing
  • Aluminum Heat Shield
  • Velocity Stack
  • Green Filters air filter
  • Filter Clamp
  • Recirculated BOV hose
  • Clamps
If any questions come up regarding this kit or any other Evo X parts you see on our website, please PM me and I'll happily get them answered for you in a timely manner. I love helping out our customers and getting them on the road is my main objective! Feel free to give me a call and let me know what I can do for you!
MAPerformance
P: 1-888-MAPerformance
E:
Maperformance is offline   Reply With Quote Quick reply to this message
Old 10-29-2015, 04:07 PM   #2
Maperformance
[Elite Merchant]
Thursday bump!
MAPerformance
E:
Old 02-19-2016, 04:30 PM   #3
Maperformance
[Elite Merchant]
Updated!
MAPerformance
E:
Old 03-06-2016, 09:07 PM   #4
jracer
jracer's Avatar
any pictures installed ?
whats the filter inner diameter ?
I have almost all MAP parts on my car .. ended up getting a ETS intake because at the time you didnt offer a stock size MAF intake.....
looks nice.. maybe ill sell the ETS .....Hmmmmmmmm
2013 EVO X GSR Wicked White
H&R springs
H&R 15mm spacers
MAP modified 3" Magna Flow cat back
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
ETS Intake
ID1000 injectors
ASNU 330 Fuel pump
Flexconverter plug and play Ethanol sensor
Tephra V3 flexfuel framework
Beatrush rear diff bushings
Torque solutions lower engine mount
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
TWM Desert Eagle shift knob
Slowpoke Tuned
385hp/375 tq ( 75%E85 Flex Fuel )
jracer is offline   Reply With Quote Quick reply to this message
Old 03-07-2016, 04:36 PM   #5
Maperformance
[Elite Merchant]
http://www.maperformance.com/product...ant=7525350915
That is the 3.5" kit installed in which looks very similar to what the 3" kit is, just larger. The intake filter specs for the 3" kit are as follows:
Mounting Inside Diameter 6.00 inches / Outside Diameter - Base 7.50 inches / Outside Diameter - Top 4.75 inches / Filter Height 6.00 inches / Inlet Type Straight
Hope this helps! I do really enjoy this intake as one of the most functional and gorgeous intakes for the Evo X especially considering the price.
Regards
Adam
MAPerformance
E:
Old 04-11-2016, 02:57 AM   #6
evox26
Hey guys I bought this intake and started to install it today so far it is really nice but I am also installing a grimmspeed 3 port boost controller and I am wondering what I should do about routing a line back to the intake ??
thanks guys
2015 Octane Blue Evo
Front Sway Bar and a Cat Back
2009 deep water blue 4-door wangler (lifted, supercharged)
2003 CBR 600RR
evox26 is offline   Reply With Quote Quick reply to this message
Old 04-11-2016, 06:39 PM   #7
Maperformance
[Elite Merchant]
thanks guys
Should fit just fine, or may require a reducer nipple fitting along the way, though I don't believe there should be any issues with fitment.
Regards
Adam
MAPerformance
E:
Old 04-11-2016, 09:15 PM   #8
evox26
Regards
Adam
there is no extra port for the line from the 3 port or even stock boost control on the intake tube
2003 CBR 600RR
Old 06-30-2016, 01:59 PM   #9
Maperformance
[Elite Merchant]
BUMP!
MAPerformance
E:
Old 07-01-2016, 09:46 PM   #10
Maperformance
[Elite Merchant]
Happy 4th of July weekend!
MAPerformance
E:
ETS Intake and IC Piping Color option... vilesyntax Evo X Vanity 19 11-21-2012 06:25 PM
MAPerformance's "Trick or Treat" Halloween Sale! Huge savings all of October! Maperformance Merchant Marketplace 0 10-05-2010 03:25 PM
