Engines in stock at MAP!!!!! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > MAPerformance
MAPerformance MAPerformance
Old 08-27-2018, 03:03 PM   #1
Maperformance
[Elite Merchant]
Maperformance's Avatar
Exclamation Engines in stock at MAP!!!!!
Here at MAPerformance, we want you to keep the horsepower flowing, and your ride out on the track and street. After your feedback regarding build times industry wide, we're working on getting you an edge on both time, while easing the cost at the same time. Take a look at what we have to offer and feel free to ask us about your needs specifically!
Engines / Heads IN STOCK
** *MAP EVOX-20MSS-S1 MAP Stg 1 Shortblock for Evo X 2.0L*
Retail $5300.00
Brand new OEM Evo X block and crankshaft, *Manley Custom pistons 86.1mm 9.0:1, Manley H beam rods, King race bearings
** *MAP EVOXMSS-20-S1-WIS MAP 2.0L Shortblock - Stage 1 Evo X, MAP supplied cores,
ARP Mains and Line Hone included, King XP Bearings, Manley Rods, Wiseco Pistons
*Retail $4500.00
MAP supplied used core evo x block and crankshaft, Wiseco k636m865 pistons, Manley H beam rods, King race bearings, ARP main studs w/ line hone.*
** *MAP EVOX-20MSS-S2 MAPerformance Stage 2 Shortblock for Evolution X 2.0L -
Retail $7124.99
Brand new OEM Evo x block and crank, Sleeved with LA 4b11t sleeves, .003" step deck resurface, Wiseco k636m86 pistons, Manley turbotuff i beam rods, King race bearings, ARP main studs, line honed mains
** *MAP EVOX-20MSSLB-S1 MAP Spec Stage 1 Longblock for Evolution X 2.0L- MAP Spec Pre-Built* * * * * * * * * * * *
*Retail $9299.99
Used engine core, block/crank/head, Manley custom pistons 86.1mm 9.0:1, Manley H beam connecting rods, King race bearings, stock main bolts, Stage 1 cylinder head service, GSC springs and retainers, GSC s2 cams, ARP head studs OEM gaskets
** *MAP EVO8MSS-23-S2 *MAPerformance 2.3L Shortblock for Evo 8 (MAP Spec Stage 2)* * * * * * * * * * *
Retail $4299.99*
Used evo 8 2.0 block, used evo 2.4 crankshaft, Manley 608005CE-4 Stroker pistons 9.0:1, Manley 14400-4 Turbo turff pro series I beam rods stroker design, ARP main studs, King race bearings
** *MAP EVO8-20MSS-S2 MAPerformance 2.0L Shortblock for Evo 8/9 (MAP Spec Stage 2)* * * * * *
Retail $5749.99
Brand new Evo 8 2.0 block and crankshaft, Wiseco K626m8525 pistons, Manley turbtuff I beam rods, King race bearings, ARP main studs *(can be made into evo 9 with MAP EVO-MOFL-BK)
** *MAP EBM-2.0MSS-23-I MAP Spec Built Shortblock Ecoboost 2.3 (Ford Focus RS / ST / Ford Mustang Ecoboost(w/ motor mount))
w/ I-Beam Rods
Retail $3920.00
Brand new Ford ecoboost 2.0 block, 2.3 crankshaft with keyway cut, Manley 87.6 extreme duty pistons 9.5:1, Manley I beam rods, MAP main studs, King race bearings. *Mustang owners must purchase MAP motor mount ($199.99 add on) to use this engine in a mustang.*
** *MAP EVOX-MSS-CHS-S3-MAP MAP Stage 3 cylinder head preparation (evo x) Used core
* *Retail $3100.00
Core Options: Used core evo x Head
Stage 3 porting service
Valves:Ferrea 6000 Standard Size** *
Valve Seals:GSC Power-Division (1010)** *
Valve Guides:Ferrea Valve guides** *
Springs and Retainers: MAP Ultimate Duty Beehive Valve Spring Kit w/ MAP Titanium Retainers (Evo X)
Valve Locks:New OEM (MN183955 x 32)** *
*No Cams - Shimming/buckets needed depending on cam choice. *$380.00 Charge for shimming with customer supplied camshafts*
** *MAP EVOX-CHS-S3-MAP MAP Stage 3 Cylinder Head Preparation (Evo X)* * * * * * * * * * * * * * * * * *
Retail $3437.98
Core Options: Brand New evo x Head
Springs and Retainers:Brian Crower single spring titanium retainer** *
** *MAP EVO8-MSCH-S3 MAP Stage 3 Cylinder Head Preparation (Evo 8) - MAP Spec * * * * * * * *
* * Retail $3856.95
Core Options: Brand New Evo 8 head
Valves: Ferrea 6000 Standard
Valve Seals: Supertech
Valve Guides: Ferrea
Springs and Retainers: Kiggly Beehive
That right! We even can hook up your slower Subaru friends!*
** *MAP WRX-4gMSS-20-S1 MAPerformance FA20 Stage 1 Shortblock Assembly (2015-2017 Subaru WRX) * * * * ** *** *** *** *** *** *** *** * * * * * * * * * * * ***Retail $4849.99
Brand new OEM Surbaru FA20 WRX block halves and crankshaft, new seals and plugs, Manley 632701CE-4 +.1mm oversize extreme duty pistons 10:1, Manley I beam connecting rods, King race bearings
** *MAP FT86-SB-FA20-CS-MAN-MAN-KIN FT86-FA20 Shortblock / CS Supplied Core / Manley Turbo Tuff Rods / Manley 10.0.1 Pistons / Balanced Rotating Assembly / ARP Main Bolts / New Subaru Crankshaft
* * *Retail $6000.00*
Used FA20 (brz/frs) block, brand new subaru crankshaft, Manley 632601CE-4 86.1mm extreme duty hone in pistons 10:1, Manley I beam connecting rods, King race bearings, ARP main bolt kit with line hone. all plugs installed.
MAPerformance
P: 1-888-MAPerformance
E:
Maperformance is offline   Reply With Quote Quick reply to this message
Old 08-30-2018, 05:43 PM   #2
Maperformance
[Elite Merchant]
Bump
MAPerformance
E:
MAP Spec Engines, Affordable & InStock! Maperformance MAPerformance 54 11-13-2017 08:20 PM
MAPerformance Evo X In Stock Engines, Affordable, Ready to go! Maperformance MAPerformance 1 10-18-2017 04:05 PM
MAP engines grafix143 Evo X Engine (4B11T) 38 05-07-2013 03:30 AM
Five-Oh fanatics: Saleen now offering 302 crate engines testdummy Automotive News, Articles & Pics 0 04-29-2008 03:30 PM
Detroit 2008: Ford launches EcoBoost gas turbo direct injection engines testdummy Automotive News, Articles & Pics 1 01-06-2008 08:23 AM
