★ eTuning by Hollywood ★ Each tune custom fit to your needs, safe, and fast replies ★ - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Merchant Marketplace > E-Tuning Services
E-Tuning Services A place for our Approved Merchants and E-Tuners to start threads and discuss services. Please do not post results in this section.
Old 12-04-2012, 02:57 AM   #11
bigstakk
bigstakk's Avatar
Is that first pic Dino with a stash?
GL with tuning! This man is a true pioneer to the 4B11 platform and a true asset to this community!
2010 GSR
bigstakk is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 03:13 AM   #12
hollywood_X
[E-Tuner]
hollywood_X's Avatar
Originally Posted by Chaz17 View Post
You and your fucking stars Hollywood.
You and your Unicorns
Old 12-04-2012, 03:54 AM   #13
Chaz17
Forum Addict
Chaz17's Avatar
<3
RALLIART FTMFW!!!!
Sept 12, 2014
RIP POUNDER
Chaz17 is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 04:23 AM   #14
thycidides
X-phile
thycidides's Avatar
Ah! Much better advertising than your initial offer of naked pictures of Dino. Congratulations on your E-Tuning status. I wish you lots of success.
Sent from my iPhone using AutoGuide.com Free App
2012 GSR Mercury Grey
334 HP / 346 ft/lbs [FONT=Tahoma]93 octane - COBB Austin Mustang dyno
COBB Intake, 3 Port, DP, HFC, quad exhaust, UICP
COBB front & rear sways
Rear Whiteline end links
Ohlins dampers
ATC Clutch
Upgraded bushings / roll center kit
RPF1 9.5 x 18 +15 - PSS 265x35
thycidides is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 06:21 AM   #15
darksyde69
darksyde69's Avatar
Noob question: what's a 'wideband'?
2011 GSR (Phantom Black)
  • Swift Spec-R springs
  • Advan RS-II (18x10 +25 Hyper Black)
  • Whiteline RCK
  • Torque Solutions short shifter
  • AMS gate selector Bushing
darksyde69 is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 06:41 AM   #16
Chaz17
Forum Addict
Chaz17's Avatar
When you install a testpipe or high flow cat or downpipe, you SHOULD monitor your "Air to Fuel Ratio" (AFR) because they alter your stock AFR. When you get a tune, one major factor taken into account is the AFR (along with boost curve). A wideband is essentially the sensor that plugs into the testpipe/high flow cat/downpipe, and attaches to a gauge and reads out the AFR so you can see what's going on.
That was the simplest/most basic explanation I can give at 3 in the morning.
RALLIART FTMFW!!!!
Sept 12, 2014
RIP POUNDER
Old 12-04-2012, 06:42 AM   #17
hollywood_X
[E-Tuner]
A sensor the logs air fuel ratios across the spectrum
Old 12-04-2012, 06:46 AM   #18
darksyde69
darksyde69's Avatar
Thanks.. Lots to learn. I'm planning to add some bolt-ons next summer, but I want to do it correct and safe, so for the time being I'm just trying to educate myself on the terminology and theory behind turbo engines.
  • Whiteline RCK
Old 12-04-2012, 07:02 AM   #19
Evo_Zero
Evo_Zero's Avatar
Im using an AEM Wideband Failsafe is that an adequate gauge?
Evo_Zero is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 10:11 AM   #20
antanas44
Member
antanas44's Avatar
Thanks.. Lots to learn. I want to do it correct and safe, so for the time being I'm just trying to educate myself on the terminology and theory behind turbo engines.
me to brotha.
antanas44 is offline   Reply With Quote Quick reply to this message
Is this tune safe? Logs and map inside Qubicker Evo X Tuning 75 09-09-2012 05:45 AM
Is it safe to run old tune on new set up..?? Louiesevox Evo X Tuning 8 05-02-2012 04:35 AM
Tune Safe? flyguycfi Evo X Tuning 7 04-28-2011 06:22 PM
Stock '10. Adding 3" TBE. Safe without tune? AndreNeves Evo X General 13 12-28-2010 05:59 PM
3 Port safe to drive to tune? Pr3z Evo X Tuning 19 03-05-2010 01:36 AM
