Rickerman Tuning - Page 4 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-11-2013, 08:47 PM   #31
OctaneBlue
OctaneBlue's Avatar
Originally Posted by MALAXA View Post
There is only one model 1000cc injector size from DW for EVO X
Then yes, those are the ones I have.
MAP : EF3 Turbo - ShortRunner Manifold - AMS : Front Mount Intercooler - Upper Intercooler Pipe - Downpipe - Test Pipe - Agency Power : - Catback Exhaust - Cobb : SF Intake -Grimmspeed : 3 Port EBCS - DW : 1000cc Injectors - 65c Pump Competiton Clutch : Stage 3 Full Face - Magnus : CMC - AEM : Uego Wideband - Defi : Boost Gauge - PVR Motorsports : Type R CF Lip - Bride : Gias II Low Maxes
459whp / 358wtq
Rickerman Tuned
OctaneBlue is offline   Reply With Quote Quick reply to this message
Old 01-11-2013, 08:54 PM   #32
chetrickerman
[E-Tuner]
chetrickerman's Avatar
No, there is 2
RIP mlomker
chetrickerman is offline   Reply With Quote Quick reply to this message
Old 01-11-2013, 11:08 PM   #33
armysoldier1073
X-phile
armysoldier1073's Avatar
Location: Where ever the Army sends me. Currently in Dayton, OH
Old and new versions right Chet?
AGP T3 5858BB (453/386), prowakeskater TUNED, DW1000 cc injectors, DW65c fuel pump, AMS UICP / INTAKE, GS 3 PORT, CP-E RESONATED CBE, RB ET500 PADS, PROSPORT HOOD DAMPERS, ACT HD 6puck w/ Streetlite flywheel, Magnus kit w/ EVO 9 CMC, GTWORKS Tarmac springs, ETS 3" FMIC / HFC, RS fog delete, Zietronic LCD to monitor WB / Boost, WhiteLine 27mm rear sway
armysoldier1073 is offline   Reply With Quote Quick reply to this message
Old 01-11-2013, 11:11 PM   #34
wwEvoXgsr
wwEvoXgsr's Avatar
Originally Posted by OctaneBlue View Post
I do believe those are the same injectors. I didn't order them from DW's website so not 100%. Should be them unless they make a different 1000cc injectors for the Evo X?
And we couldn't get it to work reading it from the rear o2. Wired it in through the serial cable and now works fine.
Is there a write up on wiring it through a serial cable?
Edit: Found it.
wwEvoXgsr is offline   Reply With Quote Quick reply to this message
Old 01-11-2013, 11:43 PM   #35
chetrickerman
[E-Tuner]
No, they have one that fits the stock injector plugs and ones that fit EV14 plugs but they both fit and work for our cars
Edit: Found it.
Just in case someone else needs it
https://www.evoxforums.com/forums/showthread.php?t=21747
RIP mlomker
Old 01-12-2013, 01:22 AM   #36
OctaneBlue
OctaneBlue's Avatar
That write up was great. And I found it much easier to do ( if you have a serial cable )
459whp / 358wtq
Rickerman Tuned
Old 01-12-2013, 09:25 AM   #37
Boost_Nerd
Boost_Nerd's Avatar
Hmmm.. glad to hear you guys are doing WOT now...i may do the serial thing too if it eleviates some headaches and cuts down on tune time trying to mess with the formulas..so you still have it hooked to the rear 02, but just use a serial cable to log it?
POWER
ETS-Full Race-UR-Rexpeed-TIAL
Turbosmart-Grimmspeed
Invidia-MAP-DW65c-GSC
HANDLING
H&R-Perrin-DME-Whiteline-Cusco
LOOKS
19x10.5 +12 SSR SP3
Project Kics-Seibon-Rexpeed
PVR-TMW-Defi-AEM-Coltspeed
Boost_Nerd is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 11:57 AM   #38
wwEvoXgsr
wwEvoXgsr's Avatar
Chet, what about wiring the wideband to a 2.5mm cable? You can then plug that in to the tactrix cable and log AFR's without a computer correct? Do you need any kind of formula like you need when tapping into the rear o2 or will it log just as easy as the serial cable?
Old 01-12-2013, 12:55 PM   #39
Liquidlink
Liquidlink's Avatar
I have all my O2s plugged in, but the serial cable is connected to the serial line coming from the WB gauge [blue wire]. Nothing is tapped into a sensor, just gauge to PC [usb], basically.
Liquidlink is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 02:47 PM   #40
OctaneBlue
OctaneBlue's Avatar
^ He is correct.
459whp / 358wtq
Rickerman Tuned
BakaUnchi Tuning Review Superhero of tuning? Murlo26 Evo X Tuning 32 09-03-2012 02:15 AM
Kaizen Tuning 2012 Season Opener and Facility Farewell! 4/29/12Kaizen Tuning 2012 Sea GTS4-R Meets, Shows, & Events 2 02-10-2012 02:29 AM
Cobb Tuning ACCESSPORT 2008 EVO X MRFor Sale: Barely used Cobb Tuning 2008 Evolution MR MJ Completed Transactions 12 08-23-2011 10:07 PM
Xtremeboost Evo X tuning Day with Jestr tuning xtremeboost Evo X Tuning 12 02-08-2010 07:49 PM
