Rickerman Tuning - Page 5 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-12-2013, 02:51 PM   #41
HappyMint
Forum Addict
HappyMint's Avatar
Originally Posted by Liquidlink View Post
I have all my O2s plugged in, but the serial cable is connected to the serial line coming from the WB gauge [blue wire]. Nothing is tapped into a sensor, just gauge to PC [usb], basically.
This is what I use too. I just route the serial through the dash and into my glove compartment. When I want to log I just open my glove box and pull out the USB sitting there and plug it into my laptop.
Love the Evo, don't own one anymore
Originally Posted by morricus
I'm drawn to them and cannot turn away. Its the same morbid fascination I'd have while watching a severely retarded person try to pick up a quarter off the street.
HappyMint is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 03:01 PM   #42
Kento240
Kento240's Avatar
^ same here. Very convenient if you ask me.
2011 GG EVO X, SSL, Aero, Sunroof
117K miles
2.2L Stroked and sleeved- Wiseco 10:1- Carrillo Pro H Beam Rods- GSC S2- ID1700- Walbaro 525LPH- Radium -8an Fuel Feed and Filter-Cosworth Rail- Aeromotive FPR- Driven Fab T4 EFR 8474 EWG Turbo Kit- MAP test pipe- HKS Hi Power CBE- OS Giken Twin Clutch- MAP CMC
Previous Cars:
2002 Eclipse GT (still own)
2009 Lancer GTS
2010 Evo X MR
2011 Evo X GSR (current)
Kento240 is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 03:01 PM   #43
Liquidlink
Liquidlink's Avatar
What did you use to 12v and ground? I tapped into the Cig/lighter//AUXoutlet and I get a low-volume high-pitch tone. I tried a different location for ground, as well, same noise. I'm thinking my tapping in the 12v aux location is causing it, but, I don't really know of a just-as-easy 12v in that glovebox local...
Liquidlink is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 03:49 PM   #44
DocBoz
DocBoz's Avatar
i did the same thing and also ran my OBDII extension cable to my glove box.
ill have to check what i spliced mine into, i dont get any noises. now if i plug my ipod into the cig lighter and charge it while its playing i get that buzz thru my speakers(extremely f***ing annoying).
Mother of god. This thread went full GTR. You never go full GTR.
<Ziptied Tuned>
DocBoz is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 03:57 PM   #45
Boost_Nerd
Boost_Nerd's Avatar
Ok wait that confused me lol..I thought you had to have the UEGO Bosch sensor in the rear 02 (testpipe) if you didnt have an extra bung welded on somewhere else, and just disable the rear 02 in the ecu?... I did alot of reading on this today since i've been stuck in my room all day (due to my flight going back to the states getting delayed ) and i got a pretty good grasp on the whole blue-wire / black-wire female serial port to USB thing..
POWER
ETS-Full Race-UR-Rexpeed-TIAL
Turbosmart-Grimmspeed
Invidia-MAP-DW65c-GSC
HANDLING
H&R-Perrin-DME-Whiteline-Cusco
LOOKS
19x10.5 +12 SSR SP3
Project Kics-Seibon-Rexpeed
PVR-TMW-Defi-AEM-Coltspeed
Boost_Nerd is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 04:00 PM   #46
DocBoz
DocBoz's Avatar
Originally Posted by wwEvoXgsr View Post
Chet, what about wiring the wideband to a 2.5mm cable? You can then plug that in to the tactrix cable and log AFR's without a computer correct? Do you need any kind of formula like you need when tapping into the rear o2 or will it log just as easy as the serial cable?
iv wondered about that, then id only have one usb cable plugged into my laptop.
<Ziptied Tuned>
Old 01-12-2013, 04:06 PM   #47
Liquidlink
Liquidlink's Avatar
Bosch .. I dunno. . . but if it's the same as the AEM, it has two connectors: 1 TO the O2 location; 2 TO serial & 12v. So both would be used. Pop you gauge sensor in the TP, and then serial used for other set of wires from gauge. (does that add to confusion?)
Old 01-12-2013, 05:05 PM   #48
HappyMint
Forum Addict
HappyMint's Avatar
I ran mine into a fuse with a fuse adapter I think.
Old 01-12-2013, 05:38 PM   #49
wwEvoXgsr
wwEvoXgsr's Avatar
Or just datalog onto the SD card and you wouldn't need any cables.
wwEvoXgsr is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 05:57 PM   #50
Joeyrukkus
This, I still use the laptop if I'm going out for some WOT pulls but other than that, 24/7 logging ftw.
2012 GSR Mods in Build thrad
You probably have the fastest closet in all of Pa lol
Joeyrukkus is offline   Reply With Quote Quick reply to this message
BakaUnchi Tuning Review Superhero of tuning? Murlo26 Evo X Tuning 32 09-03-2012 02:15 AM
Kaizen Tuning 2012 Season Opener and Facility Farewell! 4/29/12Kaizen Tuning 2012 Sea GTS4-R Meets, Shows, & Events 2 02-10-2012 02:29 AM
Cobb Tuning ACCESSPORT 2008 EVO X MRFor Sale: Barely used Cobb Tuning 2008 Evolution MR MJ Completed Transactions 12 08-23-2011 10:07 PM
Xtremeboost Evo X tuning Day with Jestr tuning xtremeboost Evo X Tuning 12 02-08-2010 07:49 PM
