Mod lists and plans - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 06-12-2019, 05:26 AM   #1
Quadrider10
Quadrider10's Avatar
Mod lists and plans
What do u guys think of this mod list in this order?
Stage 1:
-Cobb stage 3 kit (Intake, turbo back, boost control, access port)
-Cobb intercooler pipes upper and lower
-Cobb BPV
Stage 1.5:
-Pro tune
Stage 2:
-Ohlins coil overs
- Cobb sway bars
Step 3:
-Fuel injectors?
-Fuel pump?
-Recaro seats
-Rays TS06 wheels
What is your opinions on these mods and the order of them? The ones I'm curious on are if I should do the Injectors and pump earlier or later. I plan on eventually upgrading the turbo and cams, etc, but that's years down the road, so I wanna prep for that but not over due it in the beginning and waste money on stuff I could do later.
My plan for this car is to keep the outside as stock as possible but build the motor. It's going to be a DD for me so I do need it to be reliable. However, I plan on bringing it to the track every now and then, along with possibly dragging it (not often though)
Quadrider10 is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 02:49 PM   #2
jonhix
jonhix's Avatar
You could wait on the fuel mods until you get the turbo and install all of that at once and go for your 2nd tune unless you want to run e85 on the stock turbo
jonhix is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 03:40 PM   #3
mikelbring
You can save a lot of money not going with cobb's kit or the accessport. Better to go open source and just finding the parts your self not buying them off cobb.
With that said, intake, EBCS, and test pipe are the best bang for your buck and make around 350whp. Downpipe doesn't do much for stock turbo. Not worth the hassle and cost on stock turbo.
mikelbring is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 09:37 PM   #4
Quadrider10
Ok, I didn't know if fuel mods would make any difference on stock turbo, looks like I'll be saving money there until I upgrade the turbo. No plans to run e85. Idk how accessable it will be in the states I'll be driving in.
I'm actually kinda set on Cobb parts simply because they come in a "kit" look fairly stock and I also get a %15 discount from them.
I thought about just scrapping the down pipe cause I read that it does nothing for stock turbo, but ultimately for an extra $350 it will just be more prepared for a bigger turbo down the road.
The acessport port I'm also set on cause it does way more than just flashing the ECU and gives some really good data with it.
Old 06-14-2019, 10:16 PM   #5
User mikelbring has a point, and you should consider the advice you have been given. There are more limitations on the accessport than with an opensource solution. You get more logging ability over evoscan and RAXv3 logging. Also, a lot of bigger turbo options will not use the OEM style down-pipe. Totally not worth it. The best part about this platform being around for so long is that the community has tried out everything already. There are common pitfalls and regrets.
Old 06-14-2019, 11:34 PM   #6
Quadrider10
User mikelbring has a point, and you should consider the advice you have been given. There are more limitations on the accessport than with an opensource solution. You get more logging ability over evoscan and RAXv3 logging. Also, a lot of bigger turbo options will not use the OEM style down-pipe. Totally not worth it. The best part about this platform being around for so long is that the community has tried out everything already. There are common pitfalls and regrets. <img src="https://www.evoxforums.com/forums/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
That's a reason I wanted an Evo so bad, it's been around for a while lol
So u r saying don't get the down pipe or get it for bigger turbo options?
Also what are my open source options? I haven't looked into any of that nor heard of open source tuners.
Old 06-15-2019, 04:06 AM   #7
Stay on the oem downpipe until you do the turbo. A lot of the kits include the downpipe.
Take that $350 and grab a firmer front engine mount/bushing, and sway bar/end-links. Those 2 stupid little things change the feel of the car so much, really noticeable. Probably the easiest things to install too.
Browse through the forums and find an etuner. There are some good ones that you will see mentioned often.
*TACTRIX/OPENPORT cable for accessing the ECU.
*Evoscan for logging.
*ECUFlash for flashing.
Old 06-15-2019, 05:34 AM   #8
Quadrider10
Awesome! Thanks I'll look into all of this more.
Old 06-15-2019, 01:13 PM   #9
mikelbring
I have the TS motor mounts but still have stock sway bars and end-links. I heard the rear is the one to replace, did you do both front and back?
Old 06-15-2019, 04:45 PM   #10
I only did the rear sway bar and end-links, and it made a big difference. The hardest part was removing the old end-links because everything was rusted up. Did it on ramps since you want the suspension pre loaded. Front is a different story. Going to do the front next time I have the sub chassis dropped.
Do you have the rear TS mount? And did you do it at the same time as the front or separately? I have it, just haven't installed yet because I heard it can be tricky to get to some of the bolts. The $60 driveshaft solid bracket bushings are also totally worth it.
