SST OBDII Codes & Info - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 04-04-2011, 02:18 PM   #21
sheeley91
[Local Team Member]
sheeley91's Avatar
at least we know that those codes are now... thats a plus, right. Once your MR is fixed everyone owning an MR is going ot let out a long sigh........ along with you right
sheeley91 is offline   Reply With Quote Quick reply to this message
Old 08-02-2011, 11:33 PM   #22
legendary_wraps
legendary_wraps's Avatar
just threw 1808 and 2742 code on my MR today starting it up to drive home from work....
Should I be scared???
2008 EvoX MR - GG - Navi - Rockford - and More...
FP Black.... Here I come...
Mod of the century!!! Ohlins Coilovers.... Oh yeah!!!
legendary_wraps is offline   Reply With Quote Quick reply to this message
Old 08-02-2011, 11:48 PM   #23
razorlab
Ruh Roh
Bryan
2014 Evo GSR - E85 powered - 640whp
2018 Golf Alltrack - E35 powered
razorlab is offline   Reply With Quote Quick reply to this message
Old 08-02-2011, 11:50 PM   #24
legendary_wraps
Originally Posted by razorlab View Post
Ruh Roh
ruh roh is not a good answer.....
Old 12-10-2011, 07:58 PM   #25
evoxmr08
evoxmr08's Avatar
great post!!!
evoxmr08 is offline   Reply With Quote Quick reply to this message
Old 01-30-2012, 07:57 PM   #26
SleeperEvoX
SleeperEvoX's Avatar
I'm throwing codes P1870, P1871, U0100, P0725, U0141, C1472, C216E
After bolt on +E85 mod's on my 2010 SE.
I believe the P1870 and P1871 are due to overboost (running 28PSI) on stock turbo. And I have felt some clutch pressure release on WOT at peak torque. Correct me if I'm wrong but lowering boost to 27 PSI should fix this yes?
Also is there a way to increase clutch pressures with a rom patch to correct the clutch slippage?
No idea what the C1472 and C216E is???
P0725 lists as engine speed input circuit. What's causing that?
SleeperEvoX is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 11:35 AM   #27
evoxtyw
n00b
Originally Posted by Ray Knight View Post
**START** edited by kidneythief13 for picture overflow, from first post**
  • P2718: Clutch/shift pressure solenoid 1 system (Open circuit)
  • P2719: Clutch/shift pressure solenoid 1 system (Overcurrent)
  • P2720: Clutch/shift pressure solenoid 1 system (Short to ground)
  • P2721: Clutch/shift pressure solenoid 1 system (Short to power supply)
  • P2727: Clutch/shift pressure solenoid 2 system (Open circuit)
  • P2728: Clutch/shift pressure solenoid 2 system (Overcurrent)
  • P2729: Clutch/shift pressure solenoid 2 system (Short to ground)
  • P2730: Clutch/shift pressure solenoid 2 system (Short to power supply)
  • P2733: Clutch/shift switching solenoid 1, spool stuck
  • P2736: Clutch/shift switching solenoid 1 system (Open circuit)
  • P2738: Clutch/shift switching solenoid 1 system (Short to ground)
  • P2739: Clutch/shift switching solenoid 1 system (Short to power supply)
  • P2741: Fluid temperature sensor system (Gradient error)
  • P2742: Fluid temperature sensor system (Output low range out)
  • P2743: Fluid temperature sensor system (Output high range out)
  • P2766: Input shaft 2 (even number gear axle) speed sensor system (Poor performance)
  • P2809: Clutch/shift switching solenoid 2, spool stuck
  • P2812: Clutch/shift switching solenoid 2 system (Open circuit)
  • P2814: Clutch/shift switching solenoid 2 system (Short to ground)
  • P2815: Clutch/shift switching solenoid 2 system (Short to power supply)
  • U0001: Bus off
  • U0100: Engine time-out error
  • U0103: Shift lever time-out error
  • U0121: ASC time-out error
  • U0136: AWC time-out error
  • U0141: ETACS time-out error
FAIL-SAFE REFERENCE TABLE
Clutch open prohibits the vehicle from driving, and displays an occurrence of trouble to the multi information display to warn the driver.
P0702, P1803, P1804, P1805, P1806, P1807, P1857, P1858, P185D, P1866, P1868, P1872
Continues driving with the current gear fixed, and an occurrence of trouble is displayed to the multi information display to warn the driver.
P0776, P0777, P0964, P0965, P0966, P0968, P0970, P0971, P1852, P2733, P2736, P2738, P2739
Drives with the odd number gear axle (1st, 3rd, 5th gear) or with the even gear axle (2nd, 4th, 6th gear), and an occurrence of trouble is displayed to the multi information display to warn the driver.
P0715, P0716, P0753, P0758, P0841, P0842, P0843, P0846, P0847, P0848, P0973, P0974, P0976, P181B, P181C, P181E, P181F, P1820, P1821, P1822, P1824, P1825, P1826, P1827, P1829, P182A, P182B, P182C, P182E, P1831, P1832, P1833, P1835, P1836, P183D, P1844, P184B, P1855, P1859, P185B, P2718, P2719, P2720, P2721, P2728, P2729, P2730, P2766, P2809, P2812, P2814, P2815
Drives with the gears other than the gears related to the part in trouble, and an occurrence of trouble is displayed to the multi information display to warn the driver.
P1862, P1863, P186A, P186B, P1876, P1877, P1878, P1879, P187A, P187B, P187C
The creep driving cannot be performed, and displays an occurrence of trouble to the multi information display to warn the driver.
P1871, U0001, U0100
Shift shock or shift response deterioration occurs, and displays an occurrence of trouble to the multi information display to warn the driver.
P0746, P0963, P1870, P1871
Normal driving can be performed, and displays an occurrence of trouble to the multi information display to warn the driver.
P0630, P0701, P0711, P0712, P0713, P0960, P0961, P0962, P0967, P1637, P1676, P180C, P1864, P1867, P186C, P186D, P186E, P186F, P1873, P1874
P1875
**END** edited by kidneythief13 for picture overflow, from first post**
Awesome info!!! Thanks for posting this!
Sent from my GT-I9300 using AutoGuide.Com Free App
evoxtyw is offline   Reply With Quote Quick reply to this message
Old 02-23-2014, 01:10 AM   #28
alsong2002
X-phile
i need p1831, 1832, 1871 and u0100 urgently for 12 x mr
2.0L sleeved built block
Fully ported head
Kelford 214B cam with Kelford spring
ATP GTX3576R with atp 3" inlet
3.5" ETS intercooler with UICP and LICP
AMS widemouth
Speedcircuit resonated test pipe
perrin catback
Map 3.5" intake
Synapse DV
GM 3 port
Boomba fuel rail
ID1300
Walbro 450 e85
Map AFPR kit
WTF inline fuel filter
Dodson super stock clutch kit sst
AEM gauges
Radium dual catch can
5150 TUNED--- 455/361 E85, 388/320 91OCT
alsong2002 is offline   Reply With Quote Quick reply to this message
Old 02-23-2014, 01:22 AM   #29
ripnet
[Administrator]
ripnet's Avatar
In the posts above:
P1831: Shift fork position sensor 4 system (Voltage low range out)
P1832: Shift fork position sensor 4 system (Voltage high range out)
P1871: APS system (Signal abnormality)
2008 Evo X GSR
PERRIN Downpipe with high-flow cat / Catback exhaust
EIBACH Pro-Kit Lowering Springs
SAKURA Intercooler / UICP / 3" Intake
SYNAPSE Synchronic DV
GRIMMSPEED 3-port EBCS
ME Self Tune
Empire Evolution MAPerformance | SpeedCircuit | Rickerman Tuning
ripnet is offline   Reply With Quote Quick reply to this message
Old 02-23-2014, 05:22 AM   #30
alsong2002
X-phile
Are these code pretty bad? I just got tuned then did some spirit driving, after that all these codes shown up. I didn't have problems before the tune. I can't clear these codes with obd scanner and even flash back to stock, those codes didn't go away too.
Do a dealer visit necessary?
Fully ported head
AMS widemouth
perrin catback
Map 3.5" intake
Synapse DV
GM 3 port
Boomba fuel rail
ID1300
Walbro 450 e85
Map AFPR kit
AEM gauges
EVO X OBD-II Codes jmayevox Evo X Tuning 63 10-20-2015 05:20 PM
ACD codes livevil S-AWC System 12 11-26-2010 12:38 AM
2 codes P0137 BluesunsXIV Evo X Performance 6 07-24-2010 07:04 PM
Clearing codes on the Accessport Lesterh Evo X Tuning 2 10-20-2009 02:40 AM
~ Anyone Have the Evo X Color Codes? ~ DirectorSe7en Evo X Vanity 10 08-21-2008 06:16 PM
