Has anyone had issues with their brake line bracket contacting the brake hardlines in the front fender wells, or even the fender well itself with coilovers and negative camber? I am running Ohlins Road and Track with about -2.5 deg of camber and noticed the other day that my passenger break hardline was almost worn through due to contact from the bracket holding the brake lines onto the coilover. Has anyone encountered this issue and what did you do to fix it? Is it possible to trim the bracket? I have attached pictures of the damage, and you can see the white spot where it hit the inside of the fender.
