Looking to make more power but where to start? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 04-04-2019, 05:19 AM   #1
AlxGarcia
AlxGarcia's Avatar
I bought my Evo X in September of 2018 and looking to make more power into it. I learned a couple things but I’m still new to it. I will have roughly $4,000 to $4,500 budget to get it as far as I can. I was looking to see what y’all recommend? I’ve already added a cold air intake and previous owner put on a bov. I’d appreciate all the help I can get bros
AlxGarcia is offline   Reply With Quote Quick reply to this message
Old 04-04-2019, 10:38 PM   #2
LeesEvoX
LeesEvoX's Avatar
Originally Posted by AlxGarcia View Post
I bought my Evo X in September of 2018 and looking to make more power into it. I learned a couple things but Im still new to it. I will have roughly $4,000 to $4,500 budget to get it as far as I can. I was looking to see what yall recommend? Ive already added a cold air intake and previous owner put on a bov. Id appreciate all the help I can get bros
You could probably go as far as full bolt ons, an ATP turbo kit, and tuning with that budget man
Sent from my SM-G950U using Tapatalk
2013 PB Evo X GSR- Kozmic Built 2.0l (stock Sleeves) Kelford 214-b cams/Brian Crower titanium springs & retainers/ Wiseco forged pistons/Manley TT forged Rods/ETS Tubular Manifold/ETS Intake W/ Custom 3.5" MAF/ETS 4" IC/ETS UICP/Synapse DV/ID2000's
and a GTX3576R
Tuned by Kozmic @ 500awhp & 365tq (E85)
Blown Ringlands, Its what makes Subaru, a Subaru
LeesEvoX is offline   Reply With Quote Quick reply to this message
Old 04-05-2019, 11:05 PM   #3
AlxGarcia
AlxGarcia's Avatar
Appreciate it, I’ll do some research on it
Old 04-10-2019, 11:56 PM   #4
chuche831
chuche831's Avatar
I would recommend you look into just getting a full exhaust and a electronic boost controller. On 91 that should net you around 340ish whp, little more on 93. If budget still allows do injectors, fuel pump and go e85 for 400ish whp.
chuche831 is offline   Reply With Quote Quick reply to this message
Old 04-28-2019, 09:30 AM   #5
MR. EVO MR
MR. EVO MR's Avatar
For each mod that changes the airflow you need to get tuned or risk HUGE problems!
Always better off doing everything at once.
You have a few options.
Buy all the Bolton’s, install them and drive like a grandma without boosting to a reputable tuner. Or do a remote tune? Or
Drop off your car and let the tuner do everything.
MR. EVO MR is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 06:01 AM   #6
blaze2682
Do you have a tune? Find a good tuner first and get a tune. Get a wideband and boost gauge. Find out what type of software the tuner supports. Cobb AP is decent for minor bolt-ons. If you ever plan on going past bolt-ons later you are better off with Open Source. It all depends on your goals not that those goals won't change over time but, try to set a realistic goal within your budget. Save up extra funds cause things can come up. Good luck with your build.
blaze2682 is offline   Reply With Quote Quick reply to this message
Old 05-01-2019, 02:07 AM   #7
4500, if spent carefully, could yield a FBO+MHI 18k+E85 & tune.
There are some things you can leave out if you so choose. An intake at that power level isn't a necessity. A drop in filter like the cosworth would be more than fine for what you want.
Old 05-03-2019, 01:15 AM   #8
bigtimlikewhoa
bigtimlikewhoa's Avatar
You can never go wrong with a full turbo back bolt ons, wideband, boost gauge, and a tune.
bigtimlikewhoa is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 03:31 AM   #9
Strider327
Search the used market unless you really want new for everything.
Intake, Downpipe, Exhaust Manifold, 3 port boost solenoid, Injectors, Pump, Flex Fuel Kit, AFR/Boost gauge and tune.
Strider327 is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 12:20 PM   #10
mikelbring
I made this list awhile back for people asking me where to start to make 500+:
Semi Budget 500-600whp evo x (On E85)
- TPC Turbo R Spec or G Spec or GT Spec $1600-$1700
- MAP Cast Manifold $500
- WTF 500 WHP (E85) Fuel System $1275
- WTF Flex Fuel Sensor $400 *optional for flex
- MAP 3” Intake $275 (or 3.5” for over 520whp)
- Depo Racing Downpipe $190
- Depo Racing Test Pipe $100
- Depo Racing 3.5” Intercooler $250
- Depo Racing UICP $150
- Any cheap Cat Back $200-500
- EBCS $100
- Wideband $200
- Crushed OEM BPV (Or Tial QRJ)
- DF or Radium Catch Can $300
- Tune $300-500
Approx $5000-6000
mikelbring is offline   Reply With Quote Quick reply to this message
Spending some $$ on upgrades, want to make sure I'm doing it right MidWesty79 Evo X Performance 4 04-02-2019 01:37 AM
Maserati CEO says new Alfieri will finally make Geneva in 2020 testdummy Automotive News, Articles & Pics 0 03-07-2019 09:50 PM
Enjoy an excellent stopping power with Power Stop Z23 Kit + CARiD Video Review carid CARiD.com 0 12-17-2018 01:32 PM
Car won’t start (no fuel) White_Rabbit Evo X General 1 11-05-2018 10:27 PM
