Can spare wheel/tire affect S-AWD system? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > S-AWC System
S-AWC System For discussion of the S-AWC system and it's components including (but not limited to) driveshafts, differentials, programming, etc.
Old 11-10-2009, 12:08 AM   #1
mevo
Member
mevo's Avatar
Had a flat tire today (pass rear). I put in the spare and now I get S-AWD warning message that says Service Required. Not only that, the S-AWD display shows bars C and B as well on E (this letters are used in the user manual - page 3-115) when I go over 55 miles and hour.
Has anyone seen this before?
2008 PB Evo X GSR
mevo is offline   Reply With Quote Quick reply to this message
Old 11-10-2009, 12:09 AM   #2
[email protected]
[Local Team Member]
Jeremy@SSP's Avatar
I've had my factory spare on twice...never had anything like that. I Dont think you should be going over 55 with a spare, but that's just me.
Jeremy@SSP is offline   Reply With Quote Quick reply to this message
Old 11-10-2009, 12:18 AM   #3
pistolpete69916
Forum Addict
pistolpete69916's Avatar
If its a ghetto spare rim+tire like the ones you see on hondas.. Yea you shouldn't go over 55..
If the tire/wheel is exactly the same as the other 3 wheels, (check tire specs on sidewall - match them all up) then you should be ok, and it's probably just a tire pressure issue.
pistolpete69916 is offline   Reply With Quote Quick reply to this message
Old 11-10-2009, 12:40 AM   #4
mevo
Member
mevo's Avatar
Thank you guys. I used the spare that comes with the car. The Service Required warning is because the spare does not have TPMS. But what has me a bit worried is the S-AWD display. I am going to have to wait until I fix the flat tire and put the OEM wheel back on the car
2008 PB Evo X GSR
Old 11-18-2009, 04:30 PM   #5
mevo
Member
mevo's Avatar
Update. I fixed the flat and replaced the spare with the OEM wheel and tire. The "Service Required" message is gone (because I have the TPMS now); and the S-AWD display showing bars in C and B as well on E is also gone.
This weekend (as just as a test), I am going to replace the rear driver side OEM wheel/tire with the spare and I expect to see "bars" in the S-AWD display A and D
Finally, I have to say that when I took the car to the dealer for the recall, they also performed a S-AWD ECU reflash. This was before my flat tire problem
2008 PB Evo X GSR
Old 11-25-2009, 09:42 PM   #6
mevo
Member
mevo's Avatar
Experiment" concluded. I swapped the rear driver side wheel/tire combo with the spare and the S-AWD shows bars in A and D
2008 PB Evo X GSR
Old 01-21-2010, 12:36 AM   #7
berts511
Member
berts511's Avatar
Sorry to ask this ,but where is the OEM and TPMS located?
berts511 is offline   Reply With Quote Quick reply to this message
Old 01-21-2010, 12:41 AM   #8
Excalibur
Forum Addict
Excalibur's Avatar
Good info to know in case of a flat.
Excalibur is offline   Reply With Quote Quick reply to this message
Old 01-21-2010, 09:53 AM   #9
on2it
Dr. Evo?
on2it's Avatar
good investigation. thanks for sharing.
Current|HKS UICP|HKS Filter|HKS racing suction pipe kit|Modified Stock Exhaust|EcuTek FQ360 tune|ETS 3.5FMIC|Swift Springs|ACT ME-HDSS|ACT Streetlite Flywheel|
Installing
|FIC 1100cc injectors|K27 Surgetank kit+ Bosch044|
To Come
|BB FPGreen|Kelford Cams|Perrin3port|Perrin Bov|Tomei FPRegulator |Tomei FP guage|
on2it is offline   Reply With Quote Quick reply to this message
Suggestion: Winter wheel, tire fitment Thread solipsism Evo X Wheels, Suspension & Brakes 8 01-16-2011 09:49 AM
Spare tire compartment cover boostin20 '08+ Lancer Common Electronics & Audio 21 10-02-2009 05:55 PM
Lancer evolution x all wheel drive system ben_ben125 Evo X Wheels, Suspension & Brakes 2 07-08-2009 01:42 PM
tire pressure monitoring system snewman Evo X Wheels, Suspension & Brakes 4 02-22-2009 09:11 PM
New Mitsubishi Super All Wheel Control System mikeyb Evo X News 8 07-21-2007 04:16 PM
