Evo X MR Cranks and but won't Start - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 05-04-2019, 04:30 AM   #1
EvoXMan0816
Ok guys I hope you can help.
First a little background. I just finished pulling the turbo to fix an oil leak. The o-ring for the oil drain tube was jacked up and was leaking.
I just finished getting everything back together and I started it for a quick second. Maybe 5 to 10 seconds just so I could get the fluids moving and check for any leaks. It started right up and ran fine.
Then I lowered the car back down off the jack stands and finished buttoning up everything... put the strut tower brace back on, topped off the coolant and oil, etc...
Then I went to start it again and now it won't start. It cranks but no start.
This is what I have started with. I checked all the relays and they all seem to be fine... no rattles. I have the green ones. I pulled the spark plugs and they are wet and you can see the top of the pistons are wet. So that means the injectors are firing and there is fuel getting to the cylinders. I read about the evo x's flooding out if you start them and immediately turn them off like I did and people were having luck with them starting by holding the gas pedal all the way to the floor. I tried with no luck. There is also no Codes that Evoscan can find and all the wiring connections are tight and don't look damaged.
Since its super late my time I'm leaving the spark plugs out over night to see if the gas will evaporate and I'll try it again in the morning.
If that doesn't work do you guys have any other suggestions?
EvoXMan0816 is offline   Reply With Quote Quick reply to this message
Old 05-10-2019, 12:23 PM   #2
ugakirk
Did that work?
It sounds like it has to be flooded.
ugakirk is offline   Reply With Quote Quick reply to this message
Old 05-10-2019, 07:49 PM   #3
Tsane
Tsane's Avatar
I second that, sounds flooded. Where are you located?
EVO X MR
Mods:
Kosmic built HPR10r 10 plate clutch transmission
Dodson heated sump
Dodson trans cooler
Girodisc 2 piece rotors / front and rear
MHI 18k turbo
Radium fuel rail
Synapse bov
Mishimoto uicp
Driven fabrication catch can
Cobb 3 port EBCS
Sakura intake
Sakura tubular manifold
Sakura licp
Sakura 3.5" fmic intercooler
AMS downpipe
TurboXS high flow cat
HKS single exit exhaust
Varis V1 front bumper
Varis carbon v2 lip
HKS GT IV coilovers
Tsane is offline   Reply With Quote Quick reply to this message
