Trick to getting ssp cmc and the firewall???? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System
Evo X Transmission & S-AWC System Discussion for transmission, axle, driveshaft, and related systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 07-02-2011, 09:31 PM   #1
cf_apex
[Local Team Member]
cf_apex's Avatar
Cool Trick to getting ssp cmc and the firewall????
I have my assembled ssp cmc ready to go through the firewall but I can't seem to get it through. I have been at it for 4 hours. Anyone have any tips or tricks. I have the arm on it as there is no set pins just a c- clamp holding the washer and arm into the plunger. I can't see how I can do it with the arm off but then I won't be able to get the c-clamp back on with it installed.
Any help would be great I'm at my wits end.
08 Phantom Black GSR
Exedy Stage 2 HD Clutch
Ultimate Racing Catback Exhaust Dual and Testpipe
Harmon Motive Intake
ETS UICP and O2 Downpipe
AEM UEGO Wideband
On Order:
Rota Grids Hyper Black 18x9.5e20
Techna-fit SS Brake Lines
Hawk HPS Brake Pads
Rally Armour Mud Flaps
cf_apex is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 01:06 PM   #2
deathreat
thread a line from inside the car to the engine compartment. Tie it to the arm of the cmc then have someone to pull the thread while u guide the body through. I was able to do it by myself just by laying the cmc near the brake reservoir and pulling the thread slowly in and going back outside to re-arrange/redirect the cmc so it's pointing towards the hole.
When your done with puting that in, dont thread the cmc to the firewall yet since the ball and socket(attachment to the clutch pedayl) is a pita.
u gonna need to temporary attack the ball and bearing and push the clutch pedal to the floor while the ball and socket are aligned together. Then with a c-clamp or something wide that u can use to clamp the ball and socket together. Finally, just pull the clutch pedal up which pulls the cmc body back to the firewall and just screw it in.
Another method i've tried is after you bench bled the CMC and attaching it, release the clutch bleed line and push the clutch pedal down while the ball and socket are together (but not firmly attached) and then just clamp them while their on the floor. ( just make sure you close the bleed line before pulling the clutch pedal back up or u'll be sucking in air)
edit: when ur threading it in make sure to remove the socket part on the CMC to make it easier (shorter arm), or screw it all the way down.
deathreat is offline   Reply With Quote Quick reply to this message
HOW TO: Firewall Access EvoX-LI '08+ Lancer Common Electronics & Audio 14 04-26-2014 10:38 PM
Magnus Motorsports CMC + Evo 9 CMC hotdog Completed Transactions 6 02-06-2011 08:13 PM
AEM Boost Gauge Firewall Access Daskid Evo X General 20 12-10-2010 08:15 PM
SSP CMC V2/v3 Frustration. deathreat Evo X Transmission & S-AWC System 20 09-08-2010 04:13 PM
Best way to get through the firewall? XxLaNcErGTSxX Evo X General 1 12-13-2009 12:37 PM
