Ayc/ACD pump bleed - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System
Evo X Transmission & S-AWC System Discussion for transmission, axle, driveshaft, and related systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 05-11-2019, 09:03 PM   #1
Mnavares
Ayc/ACD pump bleed
I was wondering if you guys have any pointers on bleeding the ayc and ACD pump without the mut III tool. Thanks in advance.
Mnavares is offline   Reply With Quote Quick reply to this message
Old 05-12-2019, 10:35 PM   #2
mac10190
Bump.
I pulled my engine and I'm going to be putting it back soon so I'm quite curious to this as well.
2015 Lancer Evolution: Final Edition
COBB 3-Port Boost Controller
COBB SF Intake
COBB Airbox
ETS Test Pipe
Custom Duel Exhaust w/ Carven Mid-pipe Muffler
Protune by Kozmic Motorsports (309whp/310wtq) - Mustang Dyno
mac10190 is offline   Reply With Quote Quick reply to this message
Old 05-13-2019, 05:11 PM   #3
kj1060
I am also curious cause I am thinking of relocating to trunk. Don't think I can drive to dealer to have them bleed it.
kj1060 is offline   Reply With Quote Quick reply to this message
Old 05-13-2019, 08:40 PM   #4
errari-22
errari-22's Avatar
From what I have read on here is you can use a snap on scan tool to do the bleeding also evoscan has it as well and Also aslong as the lines are capped off and pump is disconnected the car can be driven.
errari-22 is offline   Reply With Quote Quick reply to this message
Old 05-14-2019, 01:29 AM   #5
KTMrider
KTMrider's Avatar
Subscribed for more info! I’ll be replacing my pump in the near future and need bleeding advice
KTMrider is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 03:05 AM   #6
Just did this process after a transmission & t-case rebuild to bleed my car:
-get the car up on ramps & jack stands, put it in NEUTRAL, apply parking brake
-loosen bleeder valve, and attach a clear hose if you can (to see air bubbles in the fluid)
-with car IN NEUTRAL and gas pedal floored, start the car and spin the steering wheel back and forth (past 90 degrees each direction) as you let your foot off the gas (triggers activation of clutch packs from pump, from what I understand)
-make sure reservoir still has plenty of ATF in it so it never goes empty
-repeat until you're bleeding clean red fluid with no air bubbles
-hope your pump isn't toast, as they seem to be the weakest point on this car
Old 05-18-2019, 10:58 PM   #7
KTMrider
KTMrider's Avatar
I’ll have to try that method once I have my pump replaced. Thanks for the info!
Old 05-24-2019, 03:22 AM   #8
Absolutely! Good luck!
Old 06-06-2019, 04:15 AM   #9
LaughingCow
If you have a tactrix you can use tephra’s bleed program. Worked really well when I used it.
LaughingCow is offline   Reply With Quote Quick reply to this message
AEM 50-1220 Fuel Pump Install questions Strider327 Evo X Performance 2 05-23-2019 09:01 PM
AYC Pump Motor keeps burning out. tricky1024 S-AWC System 7 04-24-2019 01:42 AM
ACD Pump ??? dm30213 Evo X General 2 04-07-2019 05:40 AM
FIC 2150 Injectors Pump 91 Turbosteve33 Evo X Performance 4 03-13-2019 11:15 PM
new style ac pump Rickenbacker22 Evo X General 1 01-03-2019 07:32 PM
