HOWTO: Enable Readiness for OBDII inspection after removing your o2 sensor - Page 29 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Tuning > ECUFlash / OpenECU
ECUFlash / OpenECU Subforum for discussion about ECUFlash / OpenECU software and tuning.
Old 01-09-2017, 09:09 PM   #281
razorlab
Originally Posted by ranaanar View Post
Hey Scott, will your fix solve a "diag incomplete" on an Impreza ?
I had to turn off all secondary air injection diags which now show incomplete.
Impreza? I think your lost...
Bryan
2014 Evo GSR - E85 powered - 640whp
2018 Golf Alltrack - E35 powered
razorlab is offline   Reply With Quote Quick reply to this message
Old 04-11-2017, 04:48 AM   #282
Kooldino
Dino
[Approved Merchant]
Kooldino's Avatar
Originally Posted by chetrickerman View Post
59580004
Code:
<table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="910c0" type="2D" level="2" scaling="Hex16">
	<table type="Static Y Axis" elements="2">
		<data>A0BD->6000</data>
		<data>87C2->7000</data>
	</table>
</table>
<table name="Monitor Passed(1)/Failed(0) - Read Only, Do NOT Change" category="OBD Inspection" address="910c1" type="2D" level="2" scaling="blobbits">
		<table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" elements="8">
			<data>EGR system</data>
			<data>Oxygen heater sensor</data>
			<data>Oxygen sensor</data>
			<data>A/C system refrigerant</data>
			<data>Secondary air system</data>
			<data>Evaporative system</data>
			<data>Heated catalyst</data>
			<data>Catalyst</data>
		</table>
	</table>
Dont adjust any of the other readiness tables, only this one
So if I disable the rear O2 with this patch, I get a P0137, and if i enable it, I get a P0420. What am I missing? Don't I need the other two tables under the OBD-II readiness monitor?
Kooldino is offline   Reply With Quote Quick reply to this message
Old 05-05-2017, 05:36 PM   #283
laksman91
Getting P0037 after doing this - I didn't disable P0139 or P0140. Is that why?
laksman91 is offline   Reply With Quote Quick reply to this message
Old 07-10-2018, 01:16 PM   #284
GSXRiderK6
GSXRiderK6's Avatar
Should all the codes for catalyst, rear o2 heater, random misfire, etc. be enabled in the tune; then apply the patch? (Not sure if codes will pop if they are enabled, causing me to fail).
My readiness monitors for cat and o2 read "N/A" on my handheld scanner with codes disabled and patch applied. I feel like they should read "complete" or "pass", if done correctly.
GSXRiderK6 is offline   Reply With Quote Quick reply to this message
Old 07-10-2018, 04:21 PM   #285
GSXRiderK6
GSXRiderK6's Avatar
Here's my current readout. Thanks dudes...
Old 03-03-2019, 05:53 PM   #286
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
Revive
Anyone seen this message before with Echeck (Emission Service Stations)
I tried new way to pass echeck readiness. All monitors pass and are available.
However, it will not pass due to this message. I tried with 52680015, 52680022, Tephra V1 and Tephra V3. All of them get this same error.
Just wondering if anyone seen this before at any of their stations or just they have a new way of not passing these patches.
List:
-Clipse3GT Tune -SC Built 2.0 -FP RED -COBB Hardpipes, SFI, Sway Bars -Cosworth MX1 -MDR Inlet -MAP P&P INT. & Full Race EXT.-ETS 4" FMIC -AMS DP, Fuel Rail, MM -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -Walboro 255 -Fuelab FPR -FIC 1100cc -GM 3 Port -Techna-Fit SS Lines -TWM SS/Cage Shifter -WORKS Bushings -Ohlin DFV Coilovers -Whiteline Kit -VEI Gauges -Rally Armor -PERRIN Ant. -Advan RS
Clipse3GT is offline   Reply With Quote Quick reply to this message
Old 05-19-2019, 04:20 AM   #287
TravisF
Originally Posted by ScottSpeed21 View Post
Ok I just tried this and it works, everything shows Ready like this
I went in and changed the names of the definitions so it makes more sense and everything reads correctly. I also got rid of the Availability portion since we won't change any of that.
If anyone's interested, you'd need to remove all of the current patch definitions and replace it with this
Code:
<table name="Inspection Readiness Patch" category="OBD-II" address="8feb8" type="2D" level="2" scaling="Hex16">
   <data>877A->7000</data>
  </table>
 </table>
 <table name="Inspection Monitor - Passed(0)/Failed(1) - READ ONLY Do NOT Change" category="OBD-II" address="8feb9" type="2D" level="2" scaling="blobbits">
  </table>
 </table>
Big thanks for this! I had my first and last emissions test in WA and passed easily with this patch.
TravisF is online now   Reply With Quote Quick reply to this message
Old 07-13-2019, 08:40 PM   #288
Ralliartist
Can someone tell me if these settings are right for 59580004? The main thing that I'm questioning is that the Monitor Available Settings didn't change to all 1s after making the changes to the two non-continuous patch tables.
[IMG]https://photos.app.*******/b1VLGzS1SDptv4g96[/IMG]
Ralliartist is offline   Reply With Quote Quick reply to this message
SST OBDII Codes & Info saytheb SST 34 06-11-2019 02:23 PM
blitz sbc temp sensor and pressure sensor can slot in zeitronix zt2? superlemonevo Evo X General 1 04-10-2010 04:17 PM
Removing Rear 02 Sensor Completely hotdog Evo X Engine (4B11T) 7 02-24-2010 05:43 PM
Inspection dminor04 Evo X General 8 02-24-2010 04:28 PM
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) evodicted Evo X Engine (4B11T) 3 03-28-2009 12:11 PM
