Mivec exhaust cam problem - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 11-06-2011, 11:22 PM   #11
gixxer
X-phile
gixxer's Avatar
Originally Posted by hollywood_X View Post
The 4.5 is for the stock clearances and cams etc. I have been working with A LOT of people having similar issues and the data seems to be piling up. I hope to be posting a bit of an email tonight to put some light on this.
I can not wait to read up on this !
What type of oil pressure should you have on a rebuilt engine at idle once the engine is warm ?
I met someone with an Evo 9 and he has a rebuilt engine, oil pressure at cold start was about 80 psi and when it warmed up it went down to 40 psi.
Thanks !
Complete engine build 2.2L with FP Black/Alpine sound system / /RallyArmor Mudflaps/TVM shortshifter/Girodisc stage 1/AEM analog boost & AFR gauges/Synchronic BOV/AMR coilovers / xMR dual oil catch cans / Akuma cam gear / Grimmspeed EBC / MAPerformance oil cooler - rev 2 intake + exhaust manifold ceramic coated black -
gixxer is offline   Reply With Quote Quick reply to this message
Old 11-07-2011, 12:38 AM   #12
gunzo
[Gearhead]
gunzo's Avatar
Yes no oil pressure = -35* (Full retard)
wrong .. no oil pressure is full advance ..
Use the BLUE OIL at your own risk !
The manufacturer has tested the oil
and it failed the tests.
You've been warned.
Sent with GalaxyTab 10.1 I/O
gunzo is offline   Reply With Quote Quick reply to this message
Old 11-07-2011, 12:42 AM   #13
hollywood_X
[E-Tuner]
hollywood_X's Avatar
I just posted a thread on this, monitor both and see where your cam timing goes when oil pressure drops.
Old 11-07-2011, 01:20 AM   #14
gunzo
[Gearhead]
gunzo's Avatar
what you see is not what you get
You've been warned.
Old 11-07-2011, 01:42 AM   #15
mantella
X-phile
yes that was confusing me at 1st then i relized that my full advanced was others full retard so i have to remeber to stick with ecuflash/ cobb/ evoscan data values and not actual.
mantella is offline   Reply With Quote Quick reply to this message
Old 11-10-2011, 01:28 AM   #16
gunzo
[Gearhead]
gunzo's Avatar
just make sure we're singing on the same sheet of music
Intake = max retard at start
Exhaust = max advance at start
not affected by oil pressure since its mechanical stop ..
You've been warned.
Old 12-10-2011, 05:45 AM   #17
mantella
X-phile
I never did post what all ifound that caused this. 1st the gauge i was using was wrong it had been hooked to a auto trans at work so read wrong and to low. i installed a gauge now and 21 psi at 900 rpms. 1 problem was i had a exhuast leak at the downpipe to the turbo which was small but caused extra heat on the exhuast cam solenoid making it act funny. after fixing the leak it made it better but not all fixed but i did verify the problem by putting a temp head shield there and it worked. so after fixing that. I did the stuff above like checking clearances and passages but no luck and the problem went away. I forgot that I had raised the idle to 935 to solve it. The main problem apears to be the valve springs 85 supertech dual valve springs are just alot stiffer from the factory causing issues. So raising the idle a little was enough to stabilze it.
Old 12-10-2011, 08:31 PM   #18
AkumaMotorsports
Member
This is only partially correct. The cams are designed to default to 0 on both cams in a resting state. However, they rely on oil pressure to do so. The EX cam has a helper spring to keep the cam in a neutral, or 0 deg state at idle. WHen you have a heavier spring, larger cams and lower oil pressure at idle, the Ex Cam can not stay in the '0' position and falls to -30deg.
John
AkumaMotorsports is offline   Reply With Quote Quick reply to this message
Old 12-10-2011, 09:02 PM   #19
hollywood_X
[E-Tuner]
John
Exactly! What is supposed to be only applies to a stock engine.
At idle the car is fighting to get back to zero do to the stiffer internals. The dinky spring and minimal oil pressure just can't make that happen.
Old 07-25-2013, 11:57 PM   #20
Hiboost
Hiboost's Avatar
Just had a set of Cosworth MX-1 cams installed and while the car idles like a champ after a few tweaks, as soon as the MIVEC kicks in above idle the exhaust cam wants to retard an extra -15 if I rev to 2k rpms. At idle both the intake and exhaust cams match target to actual so it appears something MIVEC related is wrong.
I'm going to go out and test if the exhaust cam has issues while under 5 / 10 /15 psi boost or if it's only cruise and off boost. Hopefully something simple but since I haven't researched it heavily yet I'm going to continue my search for an answer.
Chris Wirth
Build:
2011 Octane Blue Evo X MR
Best 1/4 Mile ET & Speed: 11.677 @ 119.06
STM Mustang Dyno: 390 whp / 360 wtq
2017 Global Time Attack - Limited AWD Class
2nd - Road Atlanta
2017 CSCS Time Attack - Street AWD Class
1st - Mosport DDT 1:38.391 (Record)
1st - TMP 1:17.644 (Record)
1st - TMP Reverse 1:23.944 (Record)
1st - Shannonville 1:59.748 (Record)
Hiboost is offline   Reply With Quote Quick reply to this message
Mivec exhaust cam issue jonvr4 Evo X Engine (4B11T) 16 09-28-2015 02:48 AM
wtb: both mivec solonoids,cam gears and both cam sensors. tsi20gawd Completed Transactions 2 08-05-2011 10:26 PM
Exhaust Side Cam bearings No GooD Names Evo X Engine (4B11T) 3 01-11-2011 11:46 AM
PO171 is triggered by exhaust problem, right bradze Evo X Engine (4B11T) 39 12-04-2010 11:08 PM
problem after cb exhaust FatalCloud Evo X Performance 14 06-04-2010 06:25 PM
