Mivec exhaust cam problem - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 08-07-2013, 05:37 AM   #21
Poondoggs
Poondoggs's Avatar
Did you guys get any CELs? Like P0014?
Poondoggs is offline   Reply With Quote Quick reply to this message
Old 08-07-2013, 06:38 AM   #22
Hiboost
Hiboost's Avatar
I had P0016 and P0014, probably was something clogging up the MIVEC filter or causing issues for the oil feeder valves. I'll know for sure if I'm good after cleaning and oil change and will report back when certain.
Chris Wirth
Build:
2011 Octane Blue Evo X MR
Best 1/4 Mile ET & Speed: 11.677 @ 119.06
STM Mustang Dyno: 390 whp / 360 wtq
2017 Global Time Attack - Limited AWD Class
2nd - Road Atlanta
2017 CSCS Time Attack - Street AWD Class
1st - Mosport DDT 1:38.391 (Record)
1st - TMP 1:17.644 (Record)
1st - TMP Reverse 1:23.944 (Record)
1st - Shannonville 1:59.748 (Record)
Hiboost is offline   Reply With Quote Quick reply to this message
Old 08-07-2013, 06:50 AM   #23
WICKED_WHITE_EVO_X
Member
WICKED_WHITE_EVO_X's Avatar
It could be timing chain stretch
WIKKED X
WICKED_WHITE_EVO_X is offline   Reply With Quote Quick reply to this message
Old 08-07-2013, 01:10 PM   #24
Hiboost
Hiboost's Avatar
The STM tech said the chain was fine and within spec but it could be the issue for others.
Chris Wirth
Build:
2nd - Road Atlanta
Old 08-07-2013, 02:53 PM   #25
Poondoggs
Poondoggs's Avatar
I had a new timing chain installed, but my tuner had access to the MUT tool so they were able to reteach the new timing chain. You need the MUT tool to do so.
Old 01-13-2014, 03:35 PM   #26
evo_q8
Member
Any updates on this?
evo_q8 is offline   Reply With Quote Quick reply to this message
Old 09-25-2015, 06:32 AM   #27
IGX
Member
I'm having the same problem now after replacing the timing chain. Any idea what is the fix for this?
Ex and In Mivec Target and Actual were always on the dot before the timing chain replacement.
IGX is offline   Reply With Quote Quick reply to this message
Old 09-25-2015, 02:14 PM   #28
Hiboost
Hiboost's Avatar
For the summer months running Royal Purple 10w40 I haven't seen it come back for 4 months now so at least for me it was operating temperature related. The most common time for it to throw a code seemed to be at cold startup below 30-40*F from what I remember but it wasn't always consistent since it usually starts as a pending code. If temps warmed up during the next few startups it would drop off the list but if they were a cold start below 30-40*F it would end up triggering a CEL.
Chris Wirth
Build:
2nd - Road Atlanta
Old 09-25-2015, 11:08 PM   #29
IGX
Member
Thanks. My In and Ex Actual and Target are now just 0.5 to 1 +/- variance. The problem seem to have went away after starting the car 3 times.
Old 05-22-2019, 09:45 PM   #30
hbagumyan
Member
Did anyone figure out this issue. I am having the same problem and can't get the car to run normally.
hbagumyan is offline   Reply With Quote Quick reply to this message
Mivec exhaust cam issue jonvr4 Evo X Engine (4B11T) 16 09-28-2015 02:48 AM
wtb: both mivec solonoids,cam gears and both cam sensors. tsi20gawd Completed Transactions 2 08-05-2011 10:26 PM
Exhaust Side Cam bearings No GooD Names Evo X Engine (4B11T) 3 01-11-2011 11:46 AM
PO171 is triggered by exhaust problem, right bradze Evo X Engine (4B11T) 39 12-04-2010 11:08 PM
problem after cb exhaust FatalCloud Evo X Performance 14 06-04-2010 06:25 PM
