Spare tire~~Yes or no ? - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 08-08-2010, 07:49 PM   #21
Jackygor
Jackygor's Avatar
Out. Mitsubishi road side assistant anyways.
Jackygor is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 08:17 PM   #22
pcload1etter
X-phile
Originally Posted by SiliconTek View Post
Removed mine, installing my supports next. I will post of some photos and how to when I get done.
I screwed the holder back in and bought a large foam square from Michaels. It holds the board fine and is held in place by the spare tire holder. Cost like $10.
Put groceries and stuff in the trunk no problemo
the bottom of the foam square was slightly hollowed then I shoved it onto the spare tire holder metal thingy.
pcload1etter is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 08:21 PM   #23
IrvineXGSR
Originally Posted by abazaba410 View Post
What are you guys putting in spot to hold up the cardboard cover?
use a toolbox. that way you'll always have your tools with you and a trunk. thats what i'm doing.
IrvineXGSR is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 08:35 PM   #24
kidneythief13
[Global Moderator]
kidneythief13's Avatar
Why don't you guys that are talking about having a support for the flimsy oem trunk board just build a bigger & stronger board out of 3/4" MDF? It's not very hard to do at all & you can get at least 2 out of 1 large sheet for $30 or so.
Graphic Design portfolio ///
kidneythief13 is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 08:59 PM   #25
abazaba410
X-phile
abazaba410's Avatar
Thats probably what I will do. Remove the foam bs from around the sub and jack and build some wood
abazaba410 is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 09:02 PM   #26
joey
Dr. Evo?
joey's Avatar
Im too lazy
--I have the itch to get back into something. Just don't know what yet......
joey is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 09:11 PM   #27
kidneythief13
[Global Moderator]
I helped build one for Justin & Noah
Old 08-08-2010, 09:19 PM   #28
cavasotti
X-phile
cavasotti's Avatar
i might not be seeing things clear, but how by just removing the tire your trunk will be bigger if there is the board thing that separates the tire compartment and the trunk? the board would still be there to delimit the trunk space, and underneath there will be a whole that would be pretty annoying to use on a daily basis cause of lifting the board all the time.. would you guys just remove everything and have the whole structure exposed? i dont get it..
cavasotti is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 09:32 PM   #29
kidneythief13
[Global Moderator]
The trunk is bigger if you remove all of the stock trunk items (minus the sub if you have one). You can then build a larger board, which will drop the stock trunk floor height (w/board) & give more room. You could also choose to store things under both the new floor (or old one, if you retained all of the foam & such). Example, my trunk:
If you look at the black plastic, you can see the indentation, where the original floor went to.
Old 08-08-2010, 09:42 PM   #30
cavasotti
X-phile
cavasotti's Avatar
that looks nice.. do you have another one from a little farther away?
Spare Tire - Onboard/Offboard? SiliconTek Evo X General 19 06-15-2010 10:34 PM
A few questions regarding riding on the spare tire. 97laxlude Evo X General 6 04-20-2010 05:53 PM
Can spare wheel/tire affect S-AWD system? mevo S-AWC System 8 01-21-2010 09:53 AM
Spare tire compartment cover boostin20 '08+ Lancer Common Electronics & Audio 21 10-02-2009 05:55 PM
Titan Tire ships world's first 63-inch tire testdummy Automotive News, Articles & Pics 8 08-01-2008 04:19 AM
