Investment Cast Stainless Steel Exhaust Manifold by MAPerformance - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > MAPerformance
MAPerformance MAPerformance
Old 10-09-2014, 02:52 PM   #1
Maperformance
[Elite Merchant]
Maperformance's Avatar
We currently have a group buy being offered right now through Oct 26, 2014!
Click here to get in on the action!
Install Video
https://www.youtube.com/watch?v=mIKyl_vJd7U
Cast Stainless Steel Exhaust Manifold for Evo X by MAPerformance
Horsepower is addicting. Chances are, you've owned your Evo X for a while and you love everything about it. We dont blame you, it's a wonderful car. But there is one design flaw in the 4B11T powerplant that we've become aware of the longer the car has been in production, and we've got a revolutionary new product that is produced with stock frame turbo owners in mind. That is the MAPerformance Stainless Steel Manifold.
Drawing from our porting and tubular exhaust manifold design experience, we've invested countless man hours into research and development of this manifold including 3D rendering, virtual flow testing, rapid prototyping, and bench testing to confirm that we have produced the best possible product for our customers.
Do you know if your OEM exhaust manifold is cracked? Not many do, and it could be robbing you of power and decreasing the life of your turbo. As one of the most popular resources for ported OEM exhaust manifolds, we have seen our fair share of Evo X Manifolds. As of late, we've gotten quite a few cracked manifolds that were presumed to be in good shape. It has become incredibly hard to find a replacement OEM exhaust manifold without a crack in the collector.
Yielding an astounding 22% average increase in exhaust flow over the OEM exhaust manifold and less imbalance this manifold will produce more power, something stock frame lovers are sure to appreciate.
Manifold Features:
• Meticulously optimized design showing a 22% average increase in exhaust gas flow over the OEM Evo 10 exhaust manifold with less imbalance between runners. Our flow tests can verify this.
• Investment Casted 310s stainless steel construction. This form of casting is stronger and cleaner than sand casting, and produces some of the smoothest runners possible.
• Provisioned to allow usage of the factory heat shield. A very important feature for you stock appearing or stock frame guys and gals!
• Includes two allen head bolts to ease installation of the manifold to cylinder head.
Manifold Benefits:
• Performance. Increased exhaust flow and reduced imbalance between the runners will improve spool characteristics and produce more power.
• Durability. Constructed from 310s stainless steel and investment casted to withstand cracking in the most demanding high temperature environments.
• Stealth. Whether it is your own personal desire to keep your upgrades on the down low or motivation from an external source you can simply install the factory heat shield and onlookers will be none the wiser.
RESULTS UPDATE!
Our Tilt powered pre-order campaign for the EVO X Investment Cast Stainless Manifold is approaching the last critical weekend and can be accessed here: https://maperformance.tilt.com/inves...performance--2
Your chance to act and save yourself 90.00 dollars on this amazing new product is coming to an end! Due to community demand, we took the time to get this manifold on the dyno to get the results that everyone has been begging for! To ensure the results were as accurate as possible, we took painstaking effort to conduct the testing with as many variables as possible being consistent:
Test Vehicle: 2010 Mitsubishi EVO X
Bottom End: Stock Sleeved 2.0L Displacement
Turbo: MAP EF4 Turbo
Tuned on E85
Stock Manifold
Time: 4:17p.m.
Dyno Room Temperature : 76 degrees
Intake Air Temperature : 80.6 degrees at start, 84.2 degrees at end.
Peak Torque Timing : 8 Degrees
Peak HP Timing : 14 Degrees
Full Boost Stock Manifold - 4937.5
MAP Investment Cast SS Manifold
Time: 4:40p.m.
Dyno Room Temperature : 78 degrees
Intake Air Temperature : 82.4 degrees at start, 84.2 degrees at end.
Full Boost MAP Manifold (Without any changes to try and improve spool time) - 5031.25
As you can see from the below graph, the results speak for themselves, demonstrating impressive gains of up to 30hp and 16 ft lbs of torque to the wheels!
Once again, our pre-sale group buy is CLOSING on Sunday, October 26th at midnight. This is the final 53 hours before we close this group buy and we want everyone who wants a manifold to act now and save themselves 90.00 dollars off MSRP! Also, to alleviate any concerns, rest assured, this manifold is already in production, whether we pre-sell 10 or 100. However, this will be the ONLY chance to save 90.00 off of MSRP! Click here to reserve yours now: https://maperformance.tilt.com/inves...performance--2
Maperformance is offline   Reply With Quote Quick reply to this message
Old 10-09-2014, 03:13 PM   #2
SpeedCircuit
[Approved Merchant]
SpeedCircuit's Avatar
Nice looking part!
Like us on facebook -
Follow us on
SpeedCircuit is offline   Reply With Quote Quick reply to this message
Old 10-09-2014, 03:18 PM   #3
Maperformance
[Elite Merchant]
Thank you! More information and pictures will be posted later today!
Matt Lutton
Sales Representative
Modern Automotive Performance
P: 1-888-MAPerformance (Ext 116)
E:
Old 10-09-2014, 04:59 PM   #4
Maperformance
[Elite Merchant]
More pictures have been added. Thanks for looking!
Matt Lutton
E:
Old 10-09-2014, 05:51 PM   #5
mistermarc
X-phile
mistermarc's Avatar
damn it could of used this a couple months ago
mistermarc is offline   Reply With Quote Quick reply to this message
Old 10-09-2014, 06:46 PM   #6
Maperformance
[Elite Merchant]
I'm sure we are going to hear that a lot. We had some ported EVO X manifolds go out not to long ago.
Matt Lutton
E:
Old 10-09-2014, 08:38 PM   #7
mistermarc
X-phile
mistermarc's Avatar
What's the time frame on getting these out to people?
Old 10-09-2014, 08:41 PM   #8
ChrisCarey
[Elite Merchant]
Our first production run should be complete in less than 45 days. To allow for inbound and outbound shipping the tilt campaign conveys that delivery to your door is expected by the end of November
Chris Carey, President
E:
MAP Products:
I have been very impressed with the EF2/EF3 turbos from MAP. Make awesome power and do not sacrifice spool. Great product from MAP.
ChrisCarey is offline   Reply With Quote Quick reply to this message
Old 10-09-2014, 09:55 PM   #9
nik.moretto
X-phile
nik.moretto's Avatar
guess i should get in on this
08 Evo GSR-Beeble Tooned 334/[email protected] 2200ft
04 VW R32 stage 4 cts turbo 474/[email protected] 2200ft
14 Tiguan R-line
Depends if you're bi or homo. A Mitsubishi Evolution is like a milkshake in that it brings all the boys to your yard.
nik.moretto is offline   Reply With Quote Quick reply to this message
Old 10-09-2014, 09:59 PM   #10
ChrisCarey
[Elite Merchant]
Indeed, keep in mind the next 3 people to preorder get our renowned port & polish service for free!
E:
MAP Products:
Uber Garage Stainless Manifold Pictures spazpilot Evo X Turbo 2 11-25-2013 07:15 PM
WTB OEM cast turbo manifold bornloser_182 Completed Transactions 3 07-19-2011 06:42 PM
JUN Stainless Exhaust Manifold Pics! kirradude1025 Evo X Performance 9 07-06-2011 06:53 PM
FS: JUN stainless turbo manifold *rare* LVSBB6 Completed Transactions 18 05-04-2011 01:32 AM
