ETACS coding with Tactrix - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 10-16-2015, 08:28 PM   #1
imdrax
Hi all, im starting to use ETACS decoder with Tactrix and wanted to start a thread with information and questions.
If you have a Tactrix cable you can download the software here-> http://etacsdecoder.com/forum/showthread.php?tid=305
then follow instructions here->
http://etacsdecoder.com/forum/showthread.php?tid=240
and here->
http://etacsdecoder.com/forum/showthread.php?tid=112
My first agenda item was disabling the TPMS. At first try I got an error message so I tried the suggestion to clear any codes and then it worked great. No more TPMS at this point, we will see how it goes after 100-500-1000 miles.
Second on my list was to disable the SRS light due to swapping stock seats into the car from a different VIN Evo x. Reading around I see that the OCM in the passenger seat is VIN coded and will cause a fault due to a VIN-mismatch. I tried to disable OCM and the light is still there.
So my question at this point is what other parameters do you think I should be messing with to get the SRS light to go off?
imdrax is offline   Reply With Quote Quick reply to this message
Old 12-01-2015, 04:32 AM   #2
iakai
n00b
have you change fog lights setting so it can be turn on without headlight is on ?
iakai is offline   Reply With Quote Quick reply to this message
Old 12-04-2015, 04:43 PM   #3
Emma
Member
Emma's Avatar
Lightbulb
Oh, cool!!! Good work from those guys!
Do you know by accident if it is possible to completely disable any "bing bing" and beep (Door open, seat belt, below 3C etc. etc.) while keeping the "click" for the indicater / turn signal?
One day I'll shoot the dashboard, all those beeping is REALLY annoying...
Emma is offline   Reply With Quote Quick reply to this message
Old 12-30-2015, 02:45 PM   #4
xBoostx_
Awesome man! THANK YOU!
xBoostx_ is offline   Reply With Quote Quick reply to this message
Old 12-30-2015, 03:10 PM   #5
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
Holy crap, this is awesome.
So how is the functionality so far?
Kooldino is offline   Reply With Quote Quick reply to this message
Old 12-30-2015, 08:07 PM   #6
ombitsmike
ombitsmike's Avatar
I did this exact thing for my TPMS light. It works.
ombitsmike is offline   Reply With Quote Quick reply to this message
Old 01-01-2016, 03:47 AM   #7
Unkn0wn
n00b
I also did this successfully on a 2008 USDM GSR
Unkn0wn is offline   Reply With Quote Quick reply to this message
Old 10-18-2016, 08:55 PM   #8
domyz
n00b
So to disable TPMS, all you need is Etacs decoder with an open port 2.0, and simply disable it via decoder options ?
2005 EVO VIII
and New owner of a 2012 MR Touring.
IX Turbo ported
GSC S1 camshafts
MAP o2 Eliminator DP Vband
MAP Short Runner Exhaust Manifold
ETS V2 LICP
ETS UICP
Milspec 100cell High flow cat
3" TBE
AEM Intake
CBRD Garrett 3.8" Intercooler
Synapse Synchronic DV
Grimmspeed 3 port
Omni 4 bar
Non CDI COP System
Whiteline bushings all around
Bilstein HD+Swift sports
Restacked rear differential
Self tuned, Speed density 91oct.
domyz is offline   Reply With Quote Quick reply to this message
Old 10-27-2016, 12:03 PM   #9
staywide8
staywide8's Avatar
Any more info? Definitely interested in doing this, would just like to know there are no other worries about problems.
staywide8 is offline   Reply With Quote Quick reply to this message
Old 10-27-2016, 02:33 PM   #10
[email protected]
Andy@AMR's Avatar
I use ETACS Decoder all the time, works great. I use my tactrix cable as well.
Mods: Daily
GS 3-port | AMR Engineering 3.5" Intake | AMR Engineering TC6776 Turbo | Turbosmart Internal Wastegate 21psi| AMR Enginering Built Block | AMR Engineering Turbo Manifold | T-1R Catback Exhaust | AMR Engineering Test Pipe | ID1000 | Walbro 450 | Synapse DV | AMR Engineering Downpipe | DriveFab Coolant/Catch Can Combo | Upgraded Upper/Lower Piping | AMR Engineering 3.5 inch Intercooler |
Tuned by AMR Engineering
2008 PB MR - 425 AWHP/325 TQ 26PSI 92 Octane Pump Gas
Andy@AMR is offline   Reply With Quote Quick reply to this message
DTC reset question for the coding people... kozmic27 ECUFlash / OpenECU 17 10-11-2018 12:27 AM
Anyone know how to do CODING in Passthru Can?!?! M0ar_l0w SST 4 06-05-2015 11:47 PM
Has ETACS gone bad? MisterO Evo X General 14 05-04-2014 07:43 PM
Urgent Help Needed: ETAC Coding RS200Z Evo X Tuning 19 01-05-2014 11:51 AM
Need Help to Disable/Enable AFS Option Coding RS200Z Evo X General 0 09-06-2013 03:05 AM
