2008 Lancer GTS 2.0L Turbo Build - 4B11 NA with RA/Evo setup - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > '08+ Lancer Common > '08+ Lancer Common General
'08+ Lancer Common General Discussion for everything that's common among ALL '08+ Lancers, including Evo, Ralliart, DE, ES, and GTS trims.
Old 03-23-2016, 03:25 PM   #1
Isaque
Member
Isaque's Avatar
Hey Guys,
So figured I'd start this up now as We're going to start preparing everything this weekend and hoping that next weekend I'll be in deep to the install.
Setup:
RA Turbo
RA Manifold
Evo X FMIC
Evo X Injectors
Evo X stock Cams
RA Turbo back exhaust with custom downpipe
Redtop Optima Battery located in rear
O2 Wideband
Ported TB
Oil Cooler
Tactrix 2.0 Cable and ECU flash
There is a lot more in this project but that's the bulk of it. I've got spare oil pan with oil bung being welded on and feed lines and oil cooler lines as well.
I've attached a few pics that I took just showing what I've picked up and what my car looks like now
The install and Tune will be done by one of the best shops around the Toronto Area. DynoTune is run by Reza and there's are few like him so looking forward to this!
Here is link to his site www.dynotuneracing.com
Stay tuned as I'll make sure to post plenty of pictures and info as I go along with this project.
I'll be doing a Dyno run of the car as it is now with just intake to see how the upgrades compare to what I spend!
ID:	245378   Click image for larger version
ID:	245386   Click image for larger version
ID:	245394   Click image for larger version
ID:	245402   Click image for larger version
Isaque is offline   Reply With Quote Quick reply to this message
Old 03-23-2016, 06:53 PM   #2
LiX
Member
LiX's Avatar
I hope that you also have intake, 3-bar MAP sensor, IAT sensor, BOV, 1 step colder spark plugs and boost controller.
In order to run CEL free you will need Evo X ECU or aftermarket fuel injection system like AEM FIC. Otherwise your MIVEC will be disabled.
LiX is offline   Reply With Quote Quick reply to this message
Old 03-24-2016, 02:03 PM   #3
Isaque
Member
Isaque's Avatar
Thanks Lix,
I have intake and BOV. Need to source the Map sensor and IAT.
Cheers
Old 07-12-2016, 04:08 PM   #4
Isaque
Member
Isaque's Avatar
Well after some Delay due to Personal matters, this is up and running again. Before turbo goes in, I'm rebuilding my spare engine to use and lowering compression. Motor is being dropped of to the shop on Friday. Once it's rebuilt and all components installed, car will be dropped off and swap will be done!
Old 08-26-2016, 12:42 PM   #5
Isaque
Member
Isaque's Avatar
Engine will be back from shop by end of next week.
Block honed, head freshened up, crank cut and polished, added Evo X springs and tappets.
Evo X cams being installed and thicker cosworth head gasket being used.
Hopefully car will be in the shop soon to do the swap.
Old 09-09-2016, 05:33 PM   #6
Isaque
Member
Isaque's Avatar
Engine is back from shop and looks great. Here are some pics.
ID:	256521   Click image for larger version
ID:	256529   Click image for larger version
Old 09-09-2016, 06:17 PM   #7
LiX
Member
LiX's Avatar
Good work, keep going
Old 09-09-2016, 06:32 PM   #8
Isaque
Member
Isaque's Avatar
Thanks Lix, Thanks for the insight also on the other things I need to have my build parts completed.
Will be updating as build moves forward! Slow and steady lol...
Old 09-09-2016, 06:53 PM   #9
CanEvo2012
Forum Addict
CanEvo2012's Avatar
Is there a particular reason you are doing this? Why not to sell your car and pick up a rebuilt or damaged Evo/RA and fix it for the same price, while having a factory-boosted vehicle?
Mods:
Old 09-09-2016, 07:03 PM   #10
Isaque
Member
Isaque's Avatar
Well... For starters my car isn't worth much as I've got a lot of KM(Miles) on it. I had the spare engine with a spun crank bearing so when I spoke to shop it wasn't out of the park with the price.
Picked up the Turbo parts for $1K so I might not have an Evo X but I'll be smiling when I'm boosting.
Cheers
Lancer GTS Turbo Built Starting - Evo X FMIC or Ralliart FMIC? Isaque '08+ Lancer Common General 6 03-17-2016 09:11 PM
My 2008 Lancer GTS CVT XxLaNcErGTSxX '08+ Lancer General 42 04-17-2011 03:27 PM
2008 Lancer GTS LancerGTS '08+ Lancer General 29 02-26-2008 10:37 PM
My 2008 Lancer GTS LancerGTS '08+ Lancer Common General 18 10-03-2007 06:44 AM
