4B11 Problems - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > '08+ Lancer Common > '08+ Lancer Common General
'08+ Lancer Common General Discussion for everything that's common among ALL '08+ Lancers, including Evo, Ralliart, DE, ES, and GTS trims.
Old 06-17-2017, 06:49 PM   #1
Quinn9008
n00b
4B11 Problems
Hi Guys,
I've recently rebuilt a 4b11 for a Galant Fortis. now the rebuild is finished and it's time to start I'm having a terrible issue.
The car is turning over but it isn't starting, I've checked the timing several times, all my grounds.
I put my scan tool (Launch) onto it and it told me that the camshaft position sensor is active P0340. I've changed both camshaft sensors and crankshaft sensors and I'm still getting the fault code and the car isn't starting.
is there anything that I might have overlooked or plainly didn't check. please bear in mind the car was starting and driving before the rebuild.
Any assistance or input would be greatly appreciated...., thanks.
Quinn9008 is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 03:45 AM   #2
renovatedkitchen
n00b
renovatedkitchen's Avatar
Was the ecu replaced?
Is it confirmed that it's getting fuel and spark?
Is it firing at all?
renovatedkitchen is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 11:36 AM   #3
Faulko
Member
This.
For what ever reason you dont have 1 or the other, possibly both.
If its fueling the plugs would be wet by now. Crank a few times and check for wet plugs, if their not wet then you have a fueling issue, as to why well that's what you have to find.
Whilst the plugs are out check for sufficient spark and plug gap.
Faulko is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 01:35 PM   #4
Quinn9008
n00b
4B11 Issues
Hi Guys,
Thanks for the input.
I am getting fuel, however, I'm not getting any spark. it's almost like the car has gone into an immobilizer mode. Which I'm not sure about. Could that be a possibility that the immobilizer could be the cause of this? And if it is how would I rectify it?
Old 06-18-2017, 03:11 PM   #5
renovatedkitchen
n00b
If you swapped the ecu it could trigger it. Look up a program called: etacs decoder. As long as you have a tactrix 2.0 cable it will connect and you can see if the immobilizer was tripped or if there is a VIN mismatch.
But more likely, are you sure everything is plugged in properly? Last I recall you can plug the wrong plug into the A/C compressor which would cause that.
Old 06-19-2017, 12:53 AM   #6
Quinn9008
n00b
4B11 Issues
Thanks very much! I will make that check in the morning. It's night time here in Barbados!
Thanks once again!
4B11 SGTCMOFO Evo X Engine (4B11T) 1 07-06-2015 11:47 PM
launch problems and power problems GSR MPofficer Evo X Transmission & S-AWC System 5 08-13-2012 04:37 AM
launch problems and power problems GSR MPofficer Evo X Performance 12 08-12-2012 05:20 PM
4b11 na redsun727 Evo X General 1 11-25-2011 05:10 AM
R.I.P...another 4B11 Imsoevox Evo X Engine (4B11T) 184 03-06-2010 11:08 PM
