AYC Pump Motor keeps burning out. - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > S-AWC System
S-AWC System For discussion of the S-AWC system and it's components including (but not limited to) driveshafts, differentials, programming, etc.
Old 04-15-2019, 01:28 PM   #1
tricky1024
n00b
hopefully someone can help me out here as i am now pulling my hair out with an issue with the AYC pump in a FQ300 SST. the pump died in January and seems the previous owner did a job on a frankinpump with a really odd motor.
either way the motor and pump where beyond help so i bough a complete refurb unit and installed.
now everytime i install the unit i bleed the system using the bleed tool you connect to the solenoids and manually bleed the system.
i start the car and hear the motor kick in/prime and turn off after 3/5 seconds, no lights on the dash. i drive 3 miles down the road and the motor dies and burns out. i have now had the motor re-built 5 times.
i am starting the think there must be another issue, maybe ayc computer or wiring but have no idea, anyone ever seen this and can you point me in the right direction?
tricky1024 is offline   Reply With Quote Quick reply to this message
Old 04-16-2019, 07:41 PM   #2
turismolover22
turismolover22's Avatar
If the motor is burning up like that, you're going to have to start chasing electrical.
It sounds like there is a short somewhere and it is activating it when it shouldn't be and burning it up
Old 04-16-2019, 10:26 PM   #3
Yxd68
Forum Addict
Yxd68's Avatar
Time to call a priest??
Build. The. Swamp.
Yxd68 is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 12:44 PM   #4
tricky1024
n00b
so when i first started (5 pumps ago now) the main wiring harness to the motor was competed melted and shot, so much so i have had to change the main motor connector to a Anderson type connector on the car side of the loom.
any idea of where i should start looking? boot?
Old 04-20-2019, 11:16 AM   #5
misdeismo
n00b
Uea, definitely seems like an electrical issue. Do you have the service manual? Probably would be a big help looking at the electrical schematic.
misdeismo is offline   Reply With Quote Quick reply to this message
Old 04-23-2019, 11:14 AM   #6
tricky1024
n00b
i dont, i will see if i can get one. thank you.
Old 04-23-2019, 05:24 PM   #7
2x4
Member
2x4's Avatar
http://www.evoxservicemanual.co.uk/
2012 MR Kozmic Tuned 296/310 -- K&N Drop in / AMS UICP / AMS FMIC / Cobb EBC / Akrapovic Turbo Back Exhaust / Walbro 255 / Ohlins R&T 10k-7k / Whiteline RLCA / Megan RTA / TE37SL / JDM Power Fold Mirrors / Do Luck Trunk
2x4 is offline   Reply With Quote Quick reply to this message
Old 04-24-2019, 01:42 AM   #8
turismolover22
I bet if you just got a whole harness from a part out that it would likely fix your issue
Old 06-26-2019, 02:37 PM   #9
Wertigo
n00b
you are jamming the engine at the moment of pressure build-up. as when pressure is set the load on the shaft increases. you could also have a skewed pump and gear
Wertigo is offline   Reply With Quote Quick reply to this message
SOLD FS: ID1000 Injectors + Walbro 255 LPH Fuel Pump GiantWinston For Sale (car parts) 0 04-08-2019 08:06 PM
ACD Pump ??? dm30213 Evo X General 2 04-07-2019 05:40 AM
FIC 2150 Injectors Pump 91 Turbosteve33 Evo X Performance 4 03-13-2019 11:15 PM
Startup GBatteries claims it can charge an EV as fast as it takes to pump gas testdummy Automotive News, Articles & Pics 1 01-15-2019 10:10 PM
new style ac pump Rickenbacker22 Evo X General 1 01-03-2019 07:32 PM
