UR Down pipe & Test pipe.... small problem - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 07-20-2008, 04:24 AM   #1
proracer718
proracer718's Avatar
Well I recently bought the Ultimate racing DP and TP. I have to say the product does look very nicely made. I went with UR one cause I have been reading no one had a problem with them.
After installing both parts and making sure everything was nice and tight I turn the car on and you can hear the difference. Car now is a bit louder but has a deep rumble to it which I love. After letting it idle for about 10 mins and reving it up a bit I go for a ride and you feel the response right away. The car feels smoother to redline and sounds mean.
So after about 30 miles after the install I am going home and step on it and all of a sudden a check engine light comes on and the car sounds different and feels like S**t. So I take it easy and park it and wait till the next day to put it on the lift which I did to check if maybe a bolt came loose or something but everything was fine. Check to see if I had an exhaust leak but didn't notice anything. I disconnected to batter to reset and once I turned the car on the light was not on anymore. So I go for a drive and it doesn't feel right. The car is very sluggish and now when I stop at a light the idle sometimes is everywhere and car even wants to shutoff at times.
My question is, is there anyway that maybe I can check for an exhaust leak with a tool or something? Also what can be causing the problem I have now even though I don't have a check engine light?
proracer718 is offline   Reply With Quote Quick reply to this message
Old 07-20-2008, 03:38 PM   #2
proracer718
Any thoughts or suggestions????
Old 07-20-2008, 06:35 PM   #3
hameedosh
hameedosh's Avatar
i was planing on buying these 2 pipes, i'll wait for an answer as well
"every man has a dream car.... this is mine"
the first Evo X in kuwait
Powered by Buschur Racing
Ported by MAPerformance
Built and Tuned by Panda Performance
hameedosh is offline   Reply With Quote Quick reply to this message
Old 07-20-2008, 08:01 PM   #4
Papi4baby
Did you try what i sugested on the other forum?
Papi4baby is offline   Reply With Quote Quick reply to this message
Old 07-21-2008, 06:37 AM   #5
hameedosh
hameedosh's Avatar
which forum ??
Old 07-21-2008, 06:55 AM   #6
untuned
n00b
I have the UR downpipe and test pipe installed and didn't have a problem. did you check what dtc you got? I have a idling issue too, but that was before my exhaust was installed. I believe there is flash for the fix, but just not in canada just yet. is the 02sensor plugged back in?
untuned is offline   Reply With Quote Quick reply to this message
Old 07-21-2008, 07:19 AM   #7
proracer718
I didn't get to check what code the car is throwing but will do so asap since the car is going to the body shop today. Both sensors were put back in there correct locations.
Old 07-28-2008, 04:58 PM   #8
proracer718
Well Finally got the car back from the body shop a few days ago and finally got to take it to autozone to check the codes.
Here are the codes that came up.......
P0137
P0131
P0102
Any help on what I should do to fix this problem is greatly appreciated.
Old 07-28-2008, 05:21 PM   #9
Kwiq Niss
Kwiq Niss's Avatar
you have to do the defouler trick with the sensor. It is reading funny since you have the test pipe and ECU thinks something is wrong with the cat. plenty of info was posted for high flow cat CEL fix
Current:
2008 GG Evo X GSR, Mud Flaps, AMS Performance CAI w/ K&N cone, Oil Catch Can, 35%(NC legal limit)SolarGard tint, Eibach Pro-Kit springs, Nav
To go:
Turbo back exhaust, cams w/ gears, larger FMIC and IC pipes, Electronic Boost Controller, Pulstar Plugs, ECU, Clutch/Flywheel combo, Engine build, head, Turbo with exhaust Mani (prolly GT35R twin-scroll kit), Intake Mani, Fuel, Body kit, Rear Sway Bar, Lighter wheels, Non plastic looking E-brake handle, CAMP2, Tein Coilovers with EDFC
Kwiq Niss is offline   Reply With Quote Quick reply to this message
Old 07-28-2008, 08:50 PM   #10
joey
Dr. Evo?
joey's Avatar
those codes arent for the cat though... are they? the code i threw with my test pipe was like P1320 or some shit. i thought that UR had the cell fix? anyway if thats the case then id buy the anti fowlers at least i did and it seems to work
--I have the itch to get back into something. Just don't know what yet......
joey is offline   Reply With Quote Quick reply to this message
