No its not normal, your car is broken and you have to buy something else.
Come on man its my first post lol do you hve to go that hard on me?No its not normal, your car is broken and you have to buy something else.
No, that still isn't right. Turbo timer has nothing to do with the clutch switch. I had a TT installed and mine still worked just fine. Take a volt meter and check continuity on the switch open and closed. The switch could be faulty. I assume it's plugged in, right?ya i understand never start the car in gear without clutch down It was just a one time experiment. But i went under the dash and actually see the little white switch that is hit when the pedal is all the way down. I think its bypassed because I have a turbo timer in the car. Does that sound correct?
Actually i found the switch and its not hooked up? I looked and cat find the plug to plug it back in? I dont know where it isNo, that still isn't right. Turbo timer has nothing to do with the clutch switch. I had a TT installed and mine still worked just fine. Take a volt meter and check continuity on the switch open and closed. The switch could be faulty. I assume it's plugged in, right?
do you know the the p;ug for the switch would be?well thats probably your issue, and yes, thats not normal.
