1 - 1 of 1 Posts
SO... long story short my rear diff is done! I was driving turned the corner and hit the gas heard a loud clanking noise, put on jacks to turn the wheel to reproduce the sound. The rear diff was rocking bad in my EVO X GSR and then I did some research and found out my suspicions were correct. Drained the fluid metal came out sure I broke the rack and pinion.*
So back to my post will the MR rear diff swap directly into my 2014 EVO X GSR if so what year MR can I swap directly without changing the axel's or mounts?*Here is the post that I was going off of, just so you understand I did my research.*
https://www.evolutionm.net/forums/evo-x-how-tos-installations/732309-how-remove-swap-rear-differential-evo-x.html
But the post are not clear on what diff I can swap directly*into my 14*EVO X GSR, I may have over read something but I need to order a rear diff and I want to make sure that I get everything that I need before I began to tear everything apart.*
So the question I need answered: Will the EVO X MR Diff swap with the EVO X GSR Diff without any other changes? If there are changes needed with the EVO X MR diff what are they?
Here is what it sounds like and what my 2014 EVO X GSR diff is doing:
https://photos.google.com/photo/AF1QipM8wkKLxlIryR1Y5AgwXb2cEJM2SXrBdDFLBXqr
1 - 1 of 1 Posts
