1 - 11 of 11 Posts
I run the same size wheels with Ohlins and iCan confirm the fronts fit just fine.
Discussion Starter #4
all depends on the wheels spoke design
Yeah I just cancelled my order the rims had a 3” lip.... guy said I needed to run 10mm spacers. I don’t feel comfortable running 10mm. Any thoughts about spacers??
I ran a H&R 10mm spacer for about a year without any issues.. as long as you dont cheap out on brand you will be fine with a spacer.
Banned
Definitely depends on the spoke design. 10mm is a big spacer to run on stock studs. 5mm -7mm is the largest you should run without extended studs. But even 7 is pushing it
1 - 11 of 11 Posts
