1 - 2 of 2 Posts
Hello guys, I recently started seen a lot of white smoke coming from my exhaust just on start up then disappearing 5 seconds later even when the engine is already warmed up (No smoke coming when accelerating tho) also my coolant level goes down with time. I might have an internal coolant leak but I’m not sure if it’s the head gasket or a crack cylinder. This is my second engine installed a little over a year ago it has 45k miles. What do you guys recommend?
Thank you for your help in advance 🙏.
Super Moderator
If you notice the coolant disappearing, check the oil. If water/coolant is getting in there, you should notice something. Check the oil cap and the oil for any sign of a milky look.
Could be a head gasket or leak somewhere else..
1 - 2 of 2 Posts
