1 - 4 of 4 Posts
Just got off the rollers w/ my completely stock 2011 X...
Baselined at 225whp/240tq @ 22psi on the KTM dyno dynamics. Unfortuneately my BCS's were NOT up to the task... Maxed out both of the BCS's and got a whopping 22.5psi :(P If I remember correctly it did "hold" ~1 psi more boost thru out the band, than the stock settings...
Ive got a GM 3-port on deck, but was curious to see if any1 else has come accross this?
and if any1 is curious @ 22.5psi, gained 32hp/38tq, ended up w/ 258whp/278tq.
Discussion Starter · #2 ·
doubt that it matters, but I did rescale the rpm axis on the boost maps for better resolution in the mid range.
Discussion Starter · #4 ·
The active maps are already maxed out from the factory. So you mean you maxed out the passive ones right?
1 psi more across seems about right with factory pills.
thanks for chimin in Bryan!
Yes, maxed out the passive ones also.
OIC. I expected to atleast, be able to "hit" 24 psi... Good to know.
Time for the gm 3-port to go in!
1 - 4 of 4 Posts
