1 - 20 of 20 Posts
Complete mod list
Powertrain/fuel system:
-ETS 3" intake
-ETS 3.5" intercooler
-ETS LICP
-ETS Recirculate downpipe
-ETS test pipe
-Ultimate racing catback
-Driven fab V3 catch can with -10AN lines
-Driven fab bolt dress up kit
-08 metal valve cover powder coated red baron and clear coated
-Password JDM carbon fiber spark plug cover
-Password JDM fuse box cover
-Password JDM strut bar
-Full race pro stock tubular manifold
-ATP GTX3576R .96A/R
-MAP UICP
-ID 1000cc Injectors
-Radium Engineering fuel rail with fuel pressure gauge
-Boost Resource Manifold blanket
-Synapse DV with yellow spring
-COBB 3 port electronic boost controller
-Deathscwerk DW65C 265lph fuel pump
-Speed circuit cam sensor shield
-MAP CMC kit
-ARP flywheel bolts
-ACT street light flywheel
-ACT HDG6 clutch kit
-ACT monoloc
-Mishimoto dual oil cooler kit
-CFM breathable oil cap
Interior/Electronics
-AEM EUGO wideband wired for serial data logging
-DSG forever driven gauge pod
-COBB AP V2 with a custom tune by Chet rickerman on husky 94
-TMW short throw kit(including trans bushing, cable bushing, Full replacement cage and big type R shift knob)
Suspension/Exterior
- Tein S-tech lowering springs
-Rexspeed vortex generator
-Rexspeed Carbon fiber fog delete
-Bayson R front lip
-diode dynamics LED License plate
-rally armour mud flaps
-Carbing AYC pump Cover
-Fast hayuka 18X8" with +22 offset and falken eurowinters(winter/storage mode)
-18X10 +22Enkie RS05RR wrapped in Michelin PSS 275/35/ZR188
-custom order hub centric motorsport tech wheel spacers Front ONLY +3mm
I think the car was starting to heat soak after a few pulls out in the hot open air. It was 33C when the car was on the dyno haha.
Nice to see some Solid numbers on our shitty 94 octane gas! What kind of dyno is it? Are you experiencing and surge with that turbo on this fuel?
How many pounds of boost you running?
Sent from my iPad using Tapatalk
Discussion Starter #4
It was a mobile dynocom.
No surge Unless I really really try in 5th gear at mid rpm with some funny throttle input
Its roughly 29-30psi give or take.
Good solid numbers, I'll probably upgrade my fuel and get retuned I'm also on a 35R, is this Gen1 or GenII?
Nice numbers man! Also tuned by Chet on husky 94 but my turbo is MHI able to hit 460whp on VD. Hope I can also take it to an actual Dyno. Where your VD number close to the actual?
Please do not compare these two turbos, the 35R is no where near its max or potential.
His 490WHP setup is basically a conservative tune.
Yeah no I'm not comparing the max potential of the 2 turbos since their are entirely different. I'm just curious how accurate was his VD numbers compared to actual dyno. I've been following his build and if I recall correctly his VD was around 430whp. And yeah it's a conservative tune from Chet.
Oh okay good.
What's your modifications?
When do you hit full boost?
I was thinking of changing my setup for something similar like the MHI or AMS custom 3076R.
MHI 18k
3 port
ETS UICP / LICP
ETS Intake
ETS 3.5 IC
AMS DP
MAP Tab Mani
ETS TP
Tomei Ex
ID1000
Walbro FP
Driven CC
Stock Block
I'm hitting full boost 4800 rpm.
Why change your setup? Oil feed line issues?
MHI 18k
3 port
ETS UICP / LICP
ETS Intake
ETS 3.5 IC
AMS DP
MAP Tab Mani
ETS TP
Tomei Ex
ID1000
Walbro FP
Driven CC
Stock Block
You mean 3800? 4800 is super laggy for a 18K. Pretty much every 18K I have tuned hits 26psi (full boost target) at 3800 rpm in third gear.
MHI 18k
3 port
ETS UICP / LICP
ETS Intake
ETS 3.5 IC
AMS DP
MAP Tab Mani
ETS TP
Tomei Ex
ID1000
Walbro FP
Driven CC
Stock Block
4800 is super laggy, full boost for me is 4400rpm.
Correct, I just noticed it. It's not as bad some days but I have to video it to actually see, I don't have no oil consumption issues or in my UICP & I'm not running any catch cans either.
Could white smoke be from my AMS Fuel I put on after I was tuned? As in I wasn't tuned for it.
And my wide band sensor went months ago black a** shit.
Discussion Starter #15
my last set of VD after I put a proper clutch and flywheel in the car where around 450-460 range. So within reason of my dyno I guess when you considered there can be 10% variance from different dynos.
Sorry - meant 3800 @ 3rd ger pull.
Do you have a VD graph to look at?? I find your numbers ridiculously high for a MHI on 94. E85 sure, not 94
Does this mobile dynocom ever come out to Edmonton?
Even my tiny HKS GTII surges in 5th and 6th on an aggressive tune. Downshift and go :neener:
1 - 20 of 20 Posts
