1 - 4 of 4 Posts
I'm just getting started with the mode23 logging with my tactrix cable and I finally got around to log a couple of WOT runs in 3rd gear last night.
I'm a bit surprised that my car is hitting about 23 psi of boost and I was wondering if this is normal/safe. My mods are in my sig.
I don't have the actual logs right now, but I'll post them up later tonight. I checked and I'm getting 2-3 counts of knock which are showing up in both runs. I don't think thats too bad is it?
thanks!!
With a couple free flowing mods, 23psi is pretty normal. 2-3 knock counts like that isn't a huge deal, and if you want to minimiize that, you can try pulling 1 degree of ignition timing right in that area you're seeing knock. Make sure to get yourself a wideband to keep an eye on the air/fuel ratios and as always, it's best to get properly tuned for your specific mods on your car.
1 - 4 of 4 Posts
