1 - 5 of 5 Posts
So I was doing a few runs and noticed I seem to be either over revving or hitting fuel cut “Hitting wall” at 7200 rpms.
I am able to hit 8500 rpm in 1st, 2nd, and 3rd no problem.
I’m thinking it may have been tuned his Way for safety but am wanting to see if any others with larger turbo and cams are seeing this? Tuner is closed today so can’t contact.
Discussion Starter #2
Some more info, car was at less then 1/2 tank. Once car hit 7k in 4th afr was at 11.0 then jumped to 12.0 then 12.7 Immediately.
Try with full tank. I'd check it out with the tuner before doing more pulls. 12.7 is pretty lean.
Discussion Starter #5
So, traction control is not your friend when revving that high. This was the issue. Was losing a bit of traction when hitting 7k and TC would kick in. Turned it OFF-OFF and am able to hit target rpm.
No SES light. Has nothing to do with Limp mode Thank goodness.
sorry figured this out a couple days after I posted. Forum has slowed down so much over the years I didn’t think I would see reply’s lol.
1 - 5 of 5 Posts
