I have a 2014 X GSR that is haunted by demons. I will get a 4WD service required light as soon as I turn the wheel while moving, it will also disable the S-AWC, and I cant change the modes between tarmac, gravel, or snow anymore. The light will disappear when I turn the car off and then back on. The code is also able to be cleared using EcuFlash DTC clear, but it does not tell me which code has been cleared. The car does have 75k miles and this light started to appear after a cold -20 degrees Fahrenheit day in the middle of winter, which lead me to believe the pump had died. However, the AYC pump still makes adequate pressure and the electric motor still runs well, and visually looks like no corrosion on the exterior. Maybe the fluid broke down under the extreme temperatures and the system should be bled? I have been unable to pull any codes using Evoscan, using either 2.9 or 2.8. And going to a Mitsu dealership is not an option because I live in rural Montana, with the closest one being a little over 500 miles away. I have checked other things that are known to cause this issue such as steering wheel angle, uneven tire diameter, bad alignment, and none of them seem to be the issue. Any suggestion before I blow 2000$ on a new pump just to find out that its not the issue?
- Thank you
- Thank you
