1 - 20 of 29 Posts
Looking to build a 550 whp evo x was wondering if anyone had a rough idea of what will be needed to do this or a spec list..? Thanks
build motor fp black on e85
Stroked*
You have to ask yourself, is 550 your absolute goal, or will you want more? If you want more, sleeves are going to be needed. After that, read around here and figure out what will fit your budget vs. What you want. I'm personally the type for overkill, so I'm building for 800 hp (minus sleeves) because my goal is similar to yours.
Like it was said, there is more then one way to skin a cat, and more then a few options to get you to 550 whp.
You need to read/learn more and decide what's best for you. Thousand ways to do it.
That doesn't settle anything. You could blow $12k doing it wrong and end up with a car you cant stand driving. Do your research and try to find what suits your wants.
12K?
Get Full bolt on and get MHI turbo, 1000 cc injectors, fuel pump, mild cam, a good E85 tune. You will love it, and you can spend rest money in strip club.
12K won't get you a 550whp Evo X. Based on your post, I would guess your going to have someone do the work. Like the OP above mention, all it would give you is a MHI full bolt-on car and tuned. ~400whp
He can get a 550whp evo with 12k... The list below would be 12.6k, but it's with a lot of room in some of the prices and should be good for way more than the 550 if he uses e85
EFR 9180 turbo kit = 5000
ID 2000 injectors = 1000
Fuel Pump = 200
GSC S2 cams = 800
Clutch = 2000
3" Exhaust = 1000
EBCS = 100
Tune = 600
Labor = varies, let's say 2000
Fuel Pump = 200
GSC S2 cams = 800
Clutch = 2000
3" Exhaust = 1000
EBCS = 100
Tune = 600
On a stock pistons and rods? He'll be over 12K after the repair bill.
I agree. Nice taste in cars btw :+1:
1 - 20 of 29 Posts
