1 - 9 of 9 Posts
Hey Guys, I have tried seaching but cannot seem to find the Idle tables for the 56890007 ROM.
My A/C compressor really drags my idle down and want to bump it back up. I just recently installed some Kelford cams and AMS 750r kit. I have re-scaled the MAF for the larger housing, zero'd out my MIVEC and bumped up my timing. She purrs like a kitten with the A/C off but will barely idle with the compressor on.
Any ideas or help would be appreciated if you know. Thanks
These don't work?
Code:
 <table name="Idle RPM #1 vs Coolant Temp 2010" address="5F678" category="Idle" type="2D" scaling="RPM8">
    <table name="Coolant Temperature" address="61A00" type="Y Axis" elements="9" scaling="TempFarenheit"/>
  </table>
  <table name="Idle RPM #2 vs Coolant Temp 2010" address="5F668" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle RPM #3 vs Coolant Temp 2010" address="56248" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle RPM #4 vs Coolant Temp 2010" address="5AB6C" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle RPM #5 vs Coolant Temp 2010" address="56258" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle RPM #6 vs Coolant Temp" address="5AB9E" category="Idle" type="2D" scaling="RPM8">
    <table name="Coolant Temperature" address="618EA" type="Y Axis" elements="8" scaling="TempFarenheit"/>
  </table>
  <table name="Idle RPM #7 vs Coolant Temp" address="5AB92" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle RPM #8 vs Coolant Temp" address="5A0E8" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle RPM #9 vs Coolant Temp" address="5A0DC" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Idle Adder #1 vs Coolant Temp" address="60E54" category="Idle" type="2D" scaling="RPM8">
    <table name="Coolant Temperature" address="61900" type="Y Axis" elements="9" scaling="TempFarenheit"/>
  </table>
  <table name="Idle Adder #2 vs Coolant Temp" address="60E62" category="Idle" type="2D" scaling="RPM8">
  </table>
  <table name="Target Idle #1" address="533CA" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #2" address="53C7A" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #3" address="53C7C" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #4" address="532E2" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #5" address="53D7E" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #6" address="532DE" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #7" address="532E4" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #8" address="53D80" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #9" address="532E0" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #10" address="54030" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #11" address="54034" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #12" address="548C0" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #13" address="548C2" category="Idle" type="1D" scaling="RPMTarget"/>
  <table name="Target Idle #14" address="54B0A" category="Idle" type="1D" scaling="RPMTarget"/>
Bryan,
I dropped that into my ROM and got Idle vs coolant tables 1-8. Is that what I should see or is there something missing?
Discussion Starter #7
I suppose I need a 56890009 ROM to do that correct? Where would be the best place to find one? If you have a 56890009 or 56890010 could you email it to me please, boostinhuey at gmail dot com
Thank you!
1 - 9 of 9 Posts
