1 - 2 of 2 Posts
Hey guys been running stock wheels for about 5 years now and was looking for new tires when i stumbled across a good deal. There is a set of rpf1’s for sale 5x114.3/ 9.5 wide +33 with almost new tires 245/40r18. My question is has anyone tried this setup on there X? I’ve read on other posts it is recommended +15–+30. Will this clear the calipers? If not will spacers help clear it? If so what size is recommended to avoid any rubbing?
They will fit. That wheel will be 19mm closer to the fender and 8mm closer to the strut compared to stock (rounded up). 245 is even a bit stretched on that wheel so you shouldn't have clearance issues. I'd replace them with a 255 minimum if you replace the tires
1 - 2 of 2 Posts
