1 - 2 of 2 Posts
Ok first off I appreciate any info I can get so thanks in advance. Long story short I need to run a new hard line from the ABS module into the passenger side wheel well. I can’t find a fitting that doesn’t leak at the ABS. My question is can anyone give me a definitive answer on what size fitting that is or will work. I’ve called multiple Mitsu dealers and no one knows and the replacement line is not in stock anywhere in the country.
The fitting itself is not what seals the line. The flare on the end of the line seals hydraulic fittings.
Make sure you are making the appropriate flare end. It should be a standard 45* double flare. If it isnt that, its a bubble flare.
Pic of the end of the old line, please?
1 - 2 of 2 Posts
