1 - 2 of 2 Posts
Anyone know if the ralliart abs sensors and the evo x sensor are compatible?
only difference I can see is the ralliart harness is slightly longer.
It shows no difference in the wiring diagrams or the circuits. The abs sensor doubles duty, also acting as a wheel speed sensor for the 4wd, asc, ayc, etc. As far as i know, the ralliart and the evo both use the same axles, which are where the teeth are that the sensor reads, and the actual harness connectors are the same. So yes.
-WILL
1 - 2 of 2 Posts
