1 - 13 of 13 Posts
Palindrome
ive been gettin the codes on my cobb ...ACD , c161e , and c161f and my cluster is lighting up with the 4 wheel drivetrain , " service required ! ", stated below...anyone have this , or know what it is , my car supposed to go in wed to dealer
Palindrome
Discussion Starter #2
anybody ?
I don't remember what the codes were for when my pump failed. However, I remember that the last letter determines whether or not the code can simply be cleared by the dealer or the pump needs replacing.
Good luck!
Mine is lit up too. I think the cold weather piled my pump up again. It sure is noisy during cornering. I hope mitsu is right that I can drive it without doing anymore damage. I haven't checked for codes yet tho.
bump!
I got the ACD c161e code, does anyone know what it means? Do i need to change my diff fluids or something?
Palindrome
Discussion Starter #8
bump!
i guess no1 knows?>?
bump for your Question ... so far i havnt had this code come up so far , the stealership did change my pump from a issue that was in the winter ...
id still like to know what this code is exactly .
I just got my clutch put in and now my evo is doin the same thing throwing C161e code and it idles funny bounces form around 500-750rpms up to 1000
If you search for a downlaodable service manual you can find things like
DTC c161e: electric pump relay circuit system (stuck) in them and the check out. just look on this site and rapidshare
Any more info on C161e??? My car started to whine again real bad, then randomly stopped and puked this code out.
1 - 13 of 13 Posts
