Hi,
I'm wondering if anyone on this forum has experienced this and can help me out with this problem I am having. I live in Calgary, and recently my ACD pump broke because of the cold weather, I took my car into Platinum to get it replaced because it is still under warranty. After they replaced the pump, he tried to connect to the ACD ECU to clear the codes but for some reason it locked him out and didn't let him read anything off the ECU and it wouldn't recognize the VIN... He tried for a couple hours to communicate with the ECU but still nothing, he told me it was probably because of my Cobb AP but I knew a couple people that replaced their pump and had a Cobb AP and they were able to clear the codes just fine at Platinum. The tech called the Mitsu hotline and Mitsu told him that I would need to get a new ACD ECU. That part is going to cost me about $1500.00 with labor, I'm wondering if anyone knows any other solution to this other than me having to drop $1500.00. I will, if I have to but I want to see if there are other alternatives before. I found a couple used ECUs on ebay for about $80.00 but I was told that they are VIN specific so it won't work on my car, does anyone else know anything about that or can I just buy it and try and clear it? Any insight on my problem would be appreciated!
Thanks.
Thanks.
