I had same issue ended up being the tune first time then came up again and had a couple leaks in ic piping
I was thinking the tune. Also my walbro 450 wasn't drilled out so I'm going to remove it and do that when it's a bit warmer out.I had same issue ended up being the tune first time then came up again and had a couple leaks in ic piping
I'd greatly appreciate it! I'll snag some logs this weekend and post them up.Post some datalogs, I can take a look.
FYI, even with the AFR in the proper range, you are always going to have some black smoke at WOT because of the necessary amount of fuel for safe operation.
Looks to me that the walboro 450 is overkill for just 1050 injectors,could be overpowering them not enough line to return excess fuel to tankSince my tune two years ago, my AFR has been all over the place. WOT it can drop down to 9.8 and I've watched it spike up to 18+. I don't daily the car, and when I do drive it, I've been driving like a grandma to try and keep the AFR where it needs to be.
I was wondering if anyone had any input or would be able to look at any logs to see if they can figure out what's going on with my AFR. I know it's running pretty rich because I'll get huge black clouds on hard acceleration.
I'll list the build and see if anyone has any input. Any help would be greatly appreciated.
2014 Evo X 60k Miles
413whp tuned on 93 octane. No e85 yet.
AMS CAI
Grimmspeed boost controller
ID1050x Injectors
Walbro 450
Garrett 3576r
MAP tubular exhaust manifold
AMS Downpipe
ETS Catted Test Pipe
ETS Ti single exit exhaust
Exedy Twin Clutch
I'm pulling the walbro out once the tank is near empty to check everything over. I don't believe the pump was drilled out prior to installation so I'll likely be doing that as well. I'll check over it!if that was me. I would be removing my fuel hanger from the fuel tank and inspecting the hell out of it. feels like it can't return enough fuel on the return line, or some fuel hose is crimped or some venturi in the hanger is clogged.
and if you have already made a boost leaker tester before, throw that on for a quick check.. otherwise give a quick turn on each intake piping clamp when the pipes are warm/hot.
funny that my first two go too's are already mentioned above., sorry I couldn't provide anything more.
It's likely overkill but I planned on going bigger once the car was paid off (it is now), and I planned on upgrading to ~1700 injectors prior to an e85 tune. Was told before I bought everything that 1050 should be alright where it's at, but would need to be upgraded if I wanted to get more power.Looks to me that the walboro 450 is overkill for just 1050 injectors,could be overpowering them not enough line to return excess fuel to tank
Will doThose datalogs wont work. Try using the Golden 2013 USDM V1 option in the Select ECU box of EvoScan.
Can do. It bogs down pretty bad sometimes if I try and go full throttle and afr shoots to the 20s. Hopefully it happens at least once to show on the logsCan you do some full throttle pulls? Most of those were only around 50% throttle.
I'll shoot you a message on facebook to try and get something set up. I appreciate you taking the time to check out the logs and give me an idea of whats going on!Your idle fuel trim is at -12%, and from what I can see in your logs, your tune can be improved quite a bit.
