Sorry, I went and looked and couldn't find on their website either. They were included in the box (which I kept for some reason).
The instructions are:
1. Remove the engine cover and the vacuum line that attaches to the PCV on the valve cover. This port will be connected to the middle chamber of the oil accumulator with the 3/8" vacuum hose and supplied clamps.
2. Remove the other end of the factory vaccum line from the intake manifold. This port will be connected to the top chamber of the oil accumulator with the supplied vacuum line, hard line, elbow and clamps.
3. Attach the 3/8" vacuum line and 1/2" vacuum line to the accumulator after verifying the drain plug is tight. Mount the accumulator to the core support on the edge of the passenger side using the supplied screw.
4. Attach the 90 degree silicone elbow to the intank manifold port with the shorter leg facing the intake manifold. Use the supplied clamps and attach the hard line to the silicone elbow.
5. Connect the 1/2" vacuum line from the top chamber of the accumulator to the supplied hard line using the supplied clamps. The middle chamber will be routed with the supplied hose to the PCV at the valve cover.
6. Rotate the accumulator so that it does not touch any other components in the engine bay. Tighten mount bolt. Make certain that the hoses are not kinked. The proper vacuum routing will allow the engine cover to fit back over the valve cover.
I also attached a pic with it installed - it took less than 30 minutes start to finish.
