1 - 3 of 3 Posts
As most of you know one of our employees picked up an EVO X this week and he has given us permission to open it up a bit and see how it ticks. Over the next few weeks we will be giving you step by step tests from EVO central here at AMS.
The following is an excerpt from Martin Musial, president and Chief tuner and Engineer here at AMS.
"The first pull I thought we had a boost leak. The A/F went off the scale rich and I can feel the engine bucking from inside the car as it was choking up on fuel. The dyno graph showed a rough power curve and to my surprise low power. A boost leak will cause a MAF car to run rich so just to be certain I did a boost leak test on the car and it was tight, not one leak. After a few pulls the power climbed and leveled out at about 238-240whp. On average a stock EVO IX puts down around 255-260whp on our dyno, so about 15-20whp more than the EVO X. Peak torque is about the same but as expected drops off up top compared to the IX. After searching the forums this looks about right as other EVO X’s are down about the same amount to the IX’s. So it looks like bad news right? Well before we get all upset there are a few things that look very promising.
We logged a bunch of parameters and found two interesting things. The biggest surprise is how rich the car is running. I feel that by leaning it out we’ll find a bunch of power, I’d guess 15-25whp just from that alone. The next thing we noticed was boost. Boost peaked out at 22psi and dropped down to only 13.5 psi at redline! A stock IX runs about 16 psi up top. If we can hold boost to 16-17psi I think that alone will be worth an extra 25-30whp. Timing was very consistent and it never pulled any timing during the pulls. If anything the timing seems to be a little bit on the aggressive side so it will be interesting to see if any gains can be had with timing adjustments. From just the air fuel ratio and boost level adjustments I’m confident that we can put down another 40-60whp. That would bring the EVO X to 280-300whp, which would be very respectable with only those modifications. The team at AMS will be working hard to bring you the latest information and improvements regarding the EVO X."
Here are some pics from the dyno test
Our UPS driver is a big AMS Fan (see his hat) We all but had to drag him out of the dyno to run the car LOL
Just out of morbid curiosity, how many miles has the car got on it from dyno runs now? ;p Really appreciate you guys sharing all this information with us!
1 - 3 of 3 Posts
