You most certainly do :rock: And if you look carefully, you'll see the boost gauge line too :shades:I see a Perrin MBC.
Either way I need a gauge pod solution.I'm not sure if you'll find a pillar solution, as there's airbags up there. Get into an accident and take some gauges to the face, that's like adding insult to injury.
Nope. The ECU cut out for the boost is at 25 pounds.No check engine light at 24 psi?
