It looks like it would be ok for some data logging but you'd still need a wideband if you're going to get it tuned. I think a boost gauge you can monitor while driving is a good idea too.
I respectfully disagree. The EvoScan GPS uses a 200 or 400 Mhz TI OMAP processor on Windows ce 5. The new android phones are dual core 1.5 GHz processors. The processor aspect is actually better on modern phones.I would never trust a phones processor for logging. I'd rather have the benefit of doubt and use something that could keep up with all the parameters checked. Who's to say all the addresses will be correct for the X anyways? I'll be VERY surprised if it can successfully read boost and knock count.
Let us know how it turns out. Good luck.
It can read boost correctly. But no knock count unless ECU is flashed. Since mine isn't, can't confirm about knock.I would never trust a phones processor for logging. I'd rather have the benefit of doubt and use something that could keep up with all the parameters checked. Who's to say all the addresses will be correct for the X anyways? I'll be VERY surprised if it can successfully read boost and knock count.
Yes, I have the Evoscan GPS nav and it misses A LOT of valuable info due to the slow processing. I only use it to really monitor my fuel trims because of this. It's slow. I compared it with another laptop and also with Tephra's knock count warning via the SES light.I respectfully disagree. The EvoScan GPS uses a 200 or 400 Mhz TI OMAP processor on Windows ce 5. The new android phones are dual core 1.5 GHz processors. The processor aspect is actually better on modern phones.
Only the latest phones are dual-core and even then, you're not really getting the full benefit of the CPU since it is also running the phone's other processes. Most phones are still single core and it's even worse in that case. At least the EvoScan's CPU is dedicated to one purpose, if i understand correctly.I respectfully disagree. The EvoScan GPS uses a 200 or 400 Mhz TI OMAP processor on Windows ce 5. The new android phones are dual core 1.5 GHz processors. The processor aspect is actually better on modern phones.
As long as my phone is hooked up to my dock and its plugged in battery should be good. Hopefully it'll work as advertised. Having this app running on a Droid RAZR should be a hood experience IMO. This phone is pretty quick.![]()
Were you trying to mount to the left of the steering wheel on the windshield? I tried that and it reached, but it didn't look very pretty and got in the way of the steering wheel.You should be good then as long as its plugged I have a droid x and car charger is crap didn't reach far enough to where I wanted it.
Try PMing Tephra on evolutionm.net. He might be able to get the actual names.my bluetooth dongle should be delivered today, and I bought the full app. I was reading that the app has a set of default options that it can check, but you can "MANUALLY" add additional things such as "KNOCK" if you know the name of it in the ecu. You need the PID, and you can enter the PID, and it will read what ever that PID is related too. Anyone familar with PID's for the Evo X? I figure this is the solution?
Also, there is a add-in for torque called torquescan, and its supose to scan for pids.
doneTry PMing Tephra on evolutionm.net. He might be able to get the actual names.
