1 - 2 of 2 Posts
Filed under: Performance, Europe, Hatchback, Audi, Luxury
Christmas just came a few days early for Audi fans with the announcement of the A1 Quattro, a high-performance, limited-edition version of Audi's subcompact hatch.
As its name would imply, the A1 Quattro comes equipped with the automaker's legendary all-wheel-drive system, with power provided by the same 2.0-liter turbocharged and direct-injected four-cylinder used in the S3. The reworked mill puts out 252 horsepower at 6,000 rpm and 258 pound-feet of torque from 2,500 to 4,500 rpm - a boost of more than 70 hp and 74 lb-ft over the standard 1.4-liter A1.
A six-speed manual shuttles that power to a Haldex AWD setup and on to center-locking 17-inch wheels that ape the original 80s-era Quattro's style. There's no word on weight, but Audi claims the hi-po A1 will match the S3's 0-60 mph time of 5.7 seconds and top out at 152 mph.
In addition to grippy 225/35 R18 rubber, the wheel wells are filled with a modified MacPherson strut suspension in front and a multi-link setup out back, while the braking hardware has been upgraded with larger discs at all four corners with black painted calipers. The electromechanical steering has also been tweaked to provide a 14.8:1 ratio, the ESP has been modified for high-performance duty and a new electronically controlled differential lock will keep wheelspin at bay. Although Audi decided to keep the rear seats in place, the AWD components have reduced trunk space to 7.4 cubic feet - or 2.1 cubes less than the standard model. Not that you care.
The exterior speaks for itself, drawing cues from past Audi concepts and a few bits from the S and RS lines, while the interior receives a new instrument panel, aluminum pedals, seriously bolstered buckets and black leather with red contrast stitching.
The A1 Quattro is an S1 in everything but name, and it's set to go on sale later next year with only 333 units on offer. And naturally, the U.S. is left out. We're as irritated as you. Get even more disappointed by reading all the details in the press blast below the fold.Continue reading Audi creates limited edition, 252-hp A1 Quattro
Audi creates limited edition, 252-hp A1 Quattro originally appeared on Autoblog on Tue, 20 Dec 2011 18:28:00 EST. Please see our terms for use of feeds.
More...
1 - 2 of 2 Posts
