1 - 9 of 9 Posts
So, I've been following EvoX guides for most things on my Ralliart. I'm pulling my engine out, and I currently have everything disconnected except the right front axle, and the left front axle stub. Every thing I've seen so far indicates i should be able to thread a bolt into the end of my axle stub, but when I look there are NO threads in the end of my axle stub. There's just a tapered hole with no threads...
How am I supposed to get this thing pulled out of the transaxle?
286948
Once I get this thing out, i'll be able to drop the engine and transmission out of the car...
Discussion Starter · #2 ·
I found this comment from a while back:
Is this accurate? I need to pull the axle stub from the passenger side of a SST car separate the transfercase from the transmission?
well shit... I guess i'm going to go into this semi blind then. I'm going to try and separate the center diff/transfer case from the transaxle today... i'll post up what i did to make it happen later today... assuming i manage to get it separated
yeah, but that's not possible when the axle stub isn't threaded...if you look at the picture closely you can see that it's impossible to thread a bold into it.
did you ever figure it out how did you pull it out if you cant thread a bolt into it?
The way you are supposed to remove that stub axle is by putting a bolt into the stub shaft and then using a slide hammer to pop it out
I misspoke. On the MR transmission you do NOT remove the stub shaft out of the driver side of the transmission. It is not designed in the same way as the GSR
1 - 9 of 9 Posts
