1 - 5 of 5 Posts
hi guys.
my car shut off out of nowhere when I came to a stop and it barely restarted. I noticed the engine temp growing quickly by ~1 degree/sec, so I pulled over.
No leaks, oil level is fine. I start the car and notice 2psi of oil pressure at 500rpm. no engine noises yet.
I had to get home, and limped myself home staying between 1k-2.5k of RPM. Going over 2.5k RPM resulted in rapid engine temp rising, and going under 1k stalled the car. I had super low oil pressure limping back home. Stop lights and traffic were a pain, as I modulated gas pedal for the car not to die. The engine developed a rattling/ticking noise which was exacerbated with giving it any throttle. codes: P0365, P0011, P0014 (mivec control valve issue)?
This has all happened after I got my valve cover powdercoated. There seemed to be some sandblast material in the baffles (don't know if this is related to my problem).
TL;DR:
-oil level fine
-no leaks
-no oil visibly being burnt
-low oil pressure
-car stalls <1k rpm
-car gets hot >2.5k rpm
-p0365,p0011,p0014 (mivec issue?)
-valve cover was powdercoated prior (sandblast material in baffles)
-rattling/ticking noise that is exacerbated with giving it gas
-AFRs looks fine, and the car can build boost
any help whatsoever is appreciated..entirely bummed out.
I had to get home,
Call a tow truck.
The engine developed a rattling/ticking noise which was exacerbated ...
Game Over, Dude!
I've seen this movie before.
ALWAYS disassemble and clean EVERYTHING that had been media blasted. Clean it multiple times before allowing it to be in the same room as an engine.
If a part or assembly can't be cleaned, do not blast it.
Call a tow truck.
Game Over, Dude!
it was supposed to be prepped by the powdercoater. I'm going to get an oil analysis.
Discussion Starter #5
Why on earth would you continue to drive it when you knew it had low oil pressure? You just created much more damage.
Either way, bearings are toast at minimum, good luck and stop driving it. Time to tear the motor down.
first time and lesson learned.
1 - 5 of 5 Posts
