1 - 20 of 46 Posts
I was looking at this thread
http://forums.evolutionm.net/evo-x-how-tos-installations/374707-evo-x-boost-gauge-install-no-splicing-no-firewall-drilling-pics-vid-clean-hell.html
and searched few others but "fuse tap" solution doesn't work for me for some reason. I tried two different fuse taps but no power when it's connected to the accessory fuses..
Is there any other place that I can tap for accessory power? I have no problem with constant or ground connection since I can use my dome light for that(as I did for my radar detector)..
Any help would be highly appreciated.
Thanks
Are you using an Add-a-fuse?
If so, do you have two fuses plugged into the add-a-fuse?
yes I meant to say add-a-fuse :D, I have one fuse plugged into the one add-a-fuse there are,however, two slots on each add-a-fuse. Not sure why
just wrap the positive wire of the boost gauge to the fuse of the 12volt adaptor/cig lighter and stick it in. Thats what i did and its been working fine.
[NEEvo President]
Thanks
See the Fuse box Diagram below (this is the one in the car). You need a 10 Amp fuse for the extra slot in the fuse tap (its inline with the wire lead). Make sure you place the one you remove into the other slot. Use Fuse 3 for Constant +12V(if needed) and Fuse 13 for switched +12V.
i got a question i use "add a fuse" thingy and plug it in fuse 3 and 13 but now my gauges wont turn off. it just light up but wont be off when i turn the car off. any help? btw i have the prosport evo gauges.
[NEEvo President]
Every gauge is different, some require constant some only need switched. If your gauge will not power off with the car then you should disconnect Fuse 3 (+12V Constant).
i did but it wont power up anymore...
oh no i didnt fry my gauge, if i take out fuse 3 where should i connect it to?
1 - 20 of 46 Posts
